toshiba 32av555d wont turn on
  • cvel
    • May 2015
    • 64
    • United Kingdom
    Hi all, I've been given this TV today and was told the capacitors need replacing but on further inspection found them to be OK I took the power board out to find on the other side something the just doesn't look right I will post a PIC shortly I will just explain what the power problem is. When TV is plugged in the red standby light comes on as normal when I try to turn on the TV via remote or TV itself the red standby light turns green for about 15-20 seconds I hear clicking in the back of the TV I believe to be normal but then the red standby light comes back on more clicking light green then back to red and so on. There is no light or flicker of the screen I also have no sound. Hope all that makes sense and someone can help it would be very much appreciated. Thank you.
  • cvel
    • May 2015
    • 64
    • United Kingdom
    Re: toshiba 32av555d wont turn on
    https://www.badcaps.net/forum/attach...1&d=1431203714
    • cvel
      • May 2015
      • 64
      • United Kingdom
      The link is to the picture of the power board its the solder that just doesn't look right to me it looks like its been broken and I don't want to re-solder it I'm unsure if its meant to be like this or not.
      • Hamie
        • Apr 2014
        • 1383
        Link doesn't work.
        • cvel
          • May 2015
          • 64
          • United Kingdom
          Thank you for your speedy reply. Have you any advice on how to upload a PIC you can access as the link seems to work for me
          • Hamie
            • Apr 2014
            • 1383
            It just says 'invalid link contact administrator' for me.
            But I'm on my phone so maybe that's the reason.
            If you're suspecting bad solder -
            You could google 'dry solder joint' and look at the images.
            Anything that looks similar give it a reflow.
            Remember also that capacitors don't have to be raised to be faulty.
            Capacitors can sometimes be kicked back to life once they are hot, try using a hairdryer and heat up the caps and see if it starts up.
            • cvel
              • May 2015
              • 64
              • United Kingdom
              Thank you will give that a go and post my results
              • vinceroger69
                • Mar 2012
                • 6714
                This may help you to post pictures.
                https://www.badcaps.net/forum/showthread.php?t=1868
                • cvel
                  • May 2015
                  • 64
                  • United Kingdom
                  Can't seem to find anything like it on google and heating caps didn't work. On the back of the power board there is 5 lines of solder but seem to break up to show a copper colour but also looks like its been scratched off I'm unsure as to re-flow these in case they are meant to be this way I don't want to cause more damage the lady I got the TV from said she had it from new and it just turned off one day and wouldn't come back on
                  • Hamie
                    • Apr 2014
                    • 1383
                    Yeah need to see pics, from your description sounds like it might be a slightly botched repair job and the person has lifted the pads and had to scrape down to the copper to re-establish a connection.
                    • cvel
                      • May 2015
                      • 64
                      • United Kingdom
                      Thank you vinceroger69
                      • cvel
                        • May 2015
                        • 64
                        • United Kingdom
                        Hope this helps
                        • Hamie
                          • Apr 2014
                          • 1383
                          Got it now, that shouldn't make a difference as the track it's still intact.
                          you could make sure by reflowing it all back together anyway.
                          • cvel
                            • May 2015
                            • 64
                            • United Kingdom
                            Great will give that a try now thank you
                            • Hamie
                              • Apr 2014
                              • 1383
                              Do you have a digital multimeter?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                in the attached post are some links for the service manual etc
                                https://www.badcaps.net/forum/showth...shiba+32av555d
                                can you also post some good clear photos of the back of your tv showing how all the boards are connected etc and maybe one seperate one of each of the boards in your tv.
                                • cvel
                                  • May 2015
                                  • 64
                                  • United Kingdom
                                  Re soldering didn't work. I borrowed my multimeter out a while back will try and trace it or get a new one here are the pics of the two boards on the back of the tv
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    The power supply doesn't have an inverter built into it, so I'm guessing there must be an inverter board under the mainboard.
                                    Really without a digital meter it's going to be hard to workout what's wrong with the TV.
                                    In the mean time, if you can unplug the inverter from the power supply. And see if the TV now powers on. If it does then you might have a problem with the backlight system.
                                    • cvel
                                      • May 2015
                                      • 64
                                      • United Kingdom
                                      Unplugged inverter from the main power board and TV acts the same
                                      • cvel
                                        • May 2015
                                        • 64
                                        • United Kingdom
                                        Have just ordered multimeter off Amazon
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                          09-06-2024, 05:27 AM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
