Phillips 520FL3603D/F7 Power Supply Dead
  • karatzdi
    • Dec 2022
    • 14
    • Cyprus
    #41
    Re: Phillips 520FL3603D/F7 Power Supply Dead
    Originally posted by R_J
    WHAT IS WRONG WITH THE POWER SUPPLY??
    Have you checked ANY voltages ?
    The resistor is ok, you are also measuring your meter lead resistance when checking the resistor. R929 is not critical it is used like a fuse, so if it does not check OPEN, it is good.
    This is the standby circuit, is it working or not? Do you have standby voltage or not?
    What is the voltage measured ACROSS C911, VCC Voltage
    Hello..Sorry I completely missed your questions here !.
    Ok the problem is that the TV has no power. Not even getting into the Standby mode when turned on from the power switch. It has no reaction from the Remote control, because the standby circuit is not working because the ZD905 got shorted out the 1ohms resistor got a bit hot and deformed / altered its value. I am not sure about the luck of IC901. There was a quote or reply to me that since ZD905 is now burned, IC901 is compromised. Therefore I did not deem necessary to plug it on mains and test.
    Yes I understood that the criticality of R929 is a fuse. I believe though as a matter of good practise that these parts must be replaced before plugged onto mains.
    2.1ohms it is the parts value as it is measured out of circuit.
    No Nothing works cause for caution reasons I did not plug it on the Mains. The IC will be available 05/23 on Mouser.
    So hence no voltages have been measured yet.
    If you guys insist to plug it I will go for it. I just need to be extra cautious. I have no variac or isolator transformer in my lab yet. The mains voltage here is 240v.
    Thank you very much R-J. ! Appreciate the effort from all in this group
    Last edited by karatzdi; 01-06-2023, 09:59 AM. Reason: Name wrong.. Iotas instead of RJ
    • karatzdi
      • Dec 2022
      • 14
      • Cyprus
      #42
      Originally posted by lotas
      Now it is clear that the positional numbers of the components do not match.
      Iotas, thank you very much for all efforts. It seems that this diagram is very close to what I have on the PCB am currently trying to fix. Actually ZD905 is located physically and connected to Ground (one leg), whilst the other is located to the last 2MΩ resistor. The locations are indeed different. But not the physical locations of the parts on the PCB.
      May be because you have schematics of a different revision from my board.
      So the Zener is 7.5v.. I got one for 10v on the PCB. Not SMD though
      Why dont you send us the complete schematic on the forum so everyone can have it ! I mean its the purpose of this forum !!
      • lotas
        • Jan 2016
        • 4845
        • Russia
        #43
        No problem, it's freely available.
        • R_J
          • Jun 2012
          • 9623
          There is no way R929 got hot and deformed, if it does not measure OPEN, it is good, ZD905 shorting would not cause the resistor to get hot.
          I suspect there was a voltage spike that caused zd905 to short, replacing the zener with the correct value should restore the standby circuit.
          You can use an incandescent lamp (60~100watt rated at your line voltage) in series with the ac line to limit the current to the power supply to check if it is drawing too much current.
          What resistance do you measure when you short the meter leads together on you meter?
          • karatzdi
            • Dec 2022
            • 14
            • Cyprus
            #45
            Thanks for input there R_J. The Resistance of the test leads is 0.2 to 0.21 ohms when shorted.
              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
              I was working on this CNC machine today found no keyboard functioning no control relay powering on
              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
              Found shorted diodes on main controller relays there are 3 of them that...
              01-07-2023, 05:43 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Andreas_de
              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
              by Andreas_de
              Hello!
              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
              04-12-2025, 10:38 AM
              03-31-2024, 02:12 PM
            • kevin_allein
              Samsung QE 75 Q 7 FGMTZG Power Supply dead
              by kevin_allein
              Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
              In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
              Does anyone have schematics for that board ?
              Any good tip, what could be the issue ?
              02-27-2025, 12:15 PM
