Philips 42PFL9703D/10 No picture
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Just bought this tv with the symptoms that it does not turn on.
    I asked the owner what happened and he said he heard a buzzing noise and the tv went to black. ( Sound and ambilight works ).
    Removed the cover and i didn't see any visible damage. Removed the PS and checked the bottom and no damage there.
    When i turn on the tv it stays on , front light flashes on start up but then stays on. Tv responds to the remote , going to standby etc but i don't get a picture on the screen. I don't see any backlight.
    Been searching the forums but most problems for this model are " tv does not turn on" so replacing capacitor "2179 + 2165" won't do much i think.
    Will post some pictures in a minute and do some measuring! If anyone has a tip for this particular model..i would appreciate it!
  • CapLeaker
    Leaking Member
    • 8212
    Re: Philips 42PFL9703D/10 No picture
    Backlight board fried or a bad ccfl is my guess.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      I replaced the caps on the PS , i now get a faint picture if i use a flashlight. So there is no backlight.
      What can i test now?
      • zomi
        • Nov 2011
        • 505
        Check you inverter board/ Boards ( if you have 2)
        Check if voltage is present there..
        Sounds like blown inverter..
        Also post picture of them so it is easer to advise you.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Ok , i will check the inverter board. Requires to remove the complete back cover right? :o
          Also , as seen on the pictures! When the TV is on i don't get any voltages on the 4 blue capacitors ( 22nF I think ). Is that correct?
          I could remove those 4 and see if i get backlight back?
          • newtothis
            • Mar 2013
            • 1556
            • england
            Ok first thing you need to do is make sure the PSU is getting the signal to start the backlights, Check all other voltages to make sure they are correct at the connector.
            If all are present check fuses on Inv boards.
            Then take it from there
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Argh haha , already removed all the cover
              Will check the inverter board first.
              What voltages do i need for the backlight? What i measured before removing everything was 25V for ambilight and 12V on a "spool". spool is right next to the blue capacitors.
              • newtothis
                • Mar 2013
                • 1556
                • england
                ~24v for backlights generally
                Can you get a picture of the entire layout of the back of the TV please. One of each board inc invertors.. Plus close ups of connectors on boards
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  These are the lamps and inverterboards. Dont see any burned lamps or spots.
                  Shall i rebuild the tv?
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Last picture is the main board connectors going to PS.
                    • Dang
                      • Aug 2013
                      • 440
                      Hi, I'm quite sure the inverter board is actually built into the main PSU board, I direct you to picture two on your first post, top left and across to the right a little. If you have a DMM you need to test as many components as you can in that area, so which one's are shorted or blown.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Removed the 4 capacitors and now the tv works! Probably 1 or 2 lamps were asking to much power from the PS.
                        Will the tv last long without those 4 caps? How much voltage drop will the lights get with those 4 caps in place?
                        On the pic its clear to see that a few lamps are not on. Are these for sale?
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          On first startup after removing the blue caps , the screen on the bottom was flickering. Can it be it needs more voltage to turn them all on?
                          • vr2yxt
                            • Jan 2017
                            • 7
                            • China
                            I have the same problem. Replace the 4 capacitors (330pF 3KV) can only work for one or two days. Before no video, the back light will flash.
                            • vr2yxt
                              • Jan 2017
                              • 7
                              • China
                              I found a circuit for the high voltage inverter. The variable resister 3224 is for current adjust for 32"and 42" TV. Should I adjust it?
                              • CapLeaker
                                Leaking Member
                                • 8212
                                either that or "beefier" caps. In what condition are the CCFL's? If they are getting kind of pink hue, then they are toasted.
                                • vr2yxt
                                  • Jan 2017
                                  • 7
                                  • China
                                  The TV are ocassionally work, so the CCFL and the active component should be fine. I intend to replace cap 2231, 2216 and 2247. These three caps are high voltage cap.
                                  • vr2yxt
                                    • Jan 2017
                                    • 7
                                    • China
                                    I have not replace the three high voltage caps but the TV is working now. It may be the new 4 caps are not stable in the beginning.
                                    • Rauni
                                      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                      by Rauni
                                      Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                      Read also that we should test what happens if we...
                                      10-01-2023, 12:06 AM
                                    • Schwoin
                                      Philips 243v5lhsb00 Monitor Picture too bright
                                      by Schwoin
                                      Hey everyone,
                                      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                      you can see them on the top half of the photo.
                                      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                      03-21-2023, 12:40 PM
                                    • madyoyo
                                      Philips 37pfl560: Yellow picture
                                      by madyoyo
                                      HI.
                                      I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                                      Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                                      05-30-2025, 10:16 AM
                                    • charlesdutcher
                                      No picture issue in Philips Chassis FTL2.1
                                      by charlesdutcher
                                      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                                      Is there someone having any symptom like this? How to fix it?
                                      Thanks in advance!​
                                      08-06-2024, 09:55 PM
                                    • groomit
                                      Philips 50PUS7363/12 Backlight but no picture
                                      by groomit
                                      I'm having trouble with above mentioned TV. Bought it defect.
                                      Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                      Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                      I can see backlight, but screen stays black.
                                      What I've tried:
                                      - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                      - Disconnect left side...
                                      11-22-2024, 02:43 PM
