Sony Visio E320-B2 TV - Burnt Mosfet
  • chozo4
    Nothing Special
    • 134
    Greetings all,
    My brothers TV decided to go belly up while watching it. Had the smell of burnt plastic and it simply stopped working shortly after and as such will not power on. He had it in a cabinet without the best airflow overall which likely contributed to failure.
    Attempting to power it only results in the typical 'clicking' during power-on from the secondary. After inspection it turns out an N-Channel Mosfet on the secondary side of the PSU not only overheated but also melted the solder it was anchored to. Ended up burning the PCB on the other side as well which made finding the culprit easy enough. The mosfet is an APM1110N of TO-252 package and I've attached the closest PDF match I can find without redirect issues.
    My issue here is mainly sourcing a replacement mosfet for the repair. I cannot seem to find any sources for an APM1110N at all and being I that don't work with Mosfets much I don't know a suitable replacement for the task.
    For reference, the power board is marked OPVP-0222
    Could use some suggestions for a more durable or at least comparable match.
    Even crap caps can be useful... such as blank rounds for prop gunfights.
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • Nooy
    VGA MOSfet permanently shorted and loss of MOSfet pad
    by Nooy
    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
    02-14-2024, 02:26 AM
  • IamPritesh
    Asus GT531GT VCORE high side mosfet pad burnt
    by IamPritesh
    So I have this Asus GT531GT whose pad is burnt and it shows short to ground 0.8 even after removing all the connected mosfets and capacitors.
    Image attached . The mosfet where the pad is burnt is PQH8102...
    08-22-2022, 01:30 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • AppleLover123
    Asus X712EA 3 volts after the first mosfet
    by AppleLover123
    Hey guys,
    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
    Now i thought something...
    12-15-2024, 07:49 AM
