BLACK SQUARE on top left screen Pioneer pro-1410HD plasma TV
  • MichaelJMcFall
    • Apr 2015
    • 13
    I tried to fix the vertical white bar on the right side of the screen.I reseated the ribbon cables but the white bar was still there. Thanks to the forum I was told it was not repairable. NOW a new problem. After about 100 screws, I put it back together. Now There is a black square on the top left side. I tried to reseat the ribbon cables but that did not work. Any suggestions?
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: BLACK SQUARE on top left screen Pioneer pro-1410HD plasma TV
    Scrap it
    Looks as tho the left hand bond has completely failed.
      Unfortunately it does look like the panel driver for that part of the panel has failed - it is worth checking you seated the Vadr power connector though.
      Be careful not to reseat all connectors with power on or shortly after as this can cause further damage.
      The ribbons are also very thin... it's possible that you tore one of them.
      • MichaelJMcFall
        • Apr 2015
        • 13
        what does the Vadr power connector look like?
          Two small wires on a 3-pin header, connects between the boards running across top & bottom and the Y-drive/X-drive boards. Approx 75V-80V on that connector.
          • MichaelJMcFall
            • Apr 2015
            • 13
            now this is weird, when I remove the 3rd & 4th ribbon from the y board, that area goes black all the way across the screen but my problem black square area s now a lighter shade of black
              How did you remove the ribbons? I thought they were bonded on this set. Maybe I'm thinking of another panel... the Kuro 9G ones are... and so are the 8G ones...
              • MichaelJMcFall
                • Apr 2015
                • 13
                they were just clipped in with a plastic locking bar
                  Yea... I am thinking of another set.
                  You're just seeing the difference between priming glow and no priming glow.
                  The drivers running along the top and bottom edges of the screen put the actual picture information on the panel.
                  The drivers running along the side (X/Y-drive plus Y-buffer) are responsible for creating the priming glow and making the actual display image appear.
                  (Modern plasma panels make very low priming glow to improve image quality.)
                  • MichaelJMcFall
                    • Apr 2015
                    • 13
                    do you think a new y upper buffer will fix this? also I was taking the upper buffer out and I guess I was still plugged in and it sparked and the tv turned off. Now when I try to turn it on it turns on for 1 second then clicks and turns off. Is there a master reset?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Probably toasted the panel completely now!
                        No as I said this will never be fixed by a y-buffer
                        The panel is bad , you may have caused additional damage but it was bad to start with unfortunately and there's nothing you can do. Sorry!
                        • Zelek11
                          Panasonic Plasma screen interference on left half of screen
                          by Zelek11
                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                          10-14-2022, 04:54 PM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • ravi_1617
                          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                          by ravi_1617
                          Hello to all ,
                          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                          on external VGA port image is perfect /normal , Attached image...
                          07-25-2025, 12:07 AM
                        • armoured_smiler
                          Panasonic Tx-40cx400b top left half screen not displaying correct
                          by armoured_smiler
                          Trying to work out if this is TFT problem or TCon issue.
                          The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                          Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                          04-08-2024, 03:40 PM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
