No Picture Samsung LED TV
  • Mikeyboy2007
    replied
    Re: No Picture Samsung LED TV
    ok probable shouldnt have but bridged a little speaker wire across fuse and plugged tv on, got multi coloured lines running all way through screen but unplugged (was only on for 2 seconds) and a little bit of smoke came from can smell burning copper or likes on the tcon ? im guessing i was wrong to try this ?
    replied
    I would use a slow blow / time delay type - the very fast acting may blow under normal in-rush currents.
  • Mikeyboy2007
    replied
    will try that, maybe a bit of speaker wire ?? board says 125v 3A which is why i was thinking this would be suitable ?
    http://www.ebay.co.uk/itm/FUSE-3A-12...item43cbb1604f
  • Alastair E
    replied
    As to that ebay fuse--I ve no idea--Whats the ratings of the original--As should be marked on either it--Or the board....
  • Alastair E
    replied
    Does it look as though its been out?
    The rating of it should be on the board. You can tack some wires to a conventional fuse of the right rating and tack that across the original as a test.....
  • Mikeyboy2007
    replied
    would this do ??
  • Mikeyboy2007
    replied
    yeah i know Alaistar E, what should i replace this with though ? i guess someones tried to repair beforehand and put in the wrong fuse ?
  • Alastair E
    replied
    Originally posted by Mikeyboy2007
    measured voltage on fuse and got 12.65v in and 0.03v out
    Come on Mikey!
    IF there's 12v one end of fuse and nothing the other--
    WHAT Does THAT mean! You been doing these long enough now to Know the answer!!
  • Mikeyboy2007
    replied
  • newtothis
    replied
    Just check voltage at either side of the fuse
  • Mikeyboy2007
    replied
    do i just test it as if im testing a regular fuse ? should i test the voltage points next to the fuse also ?
    replied
    Green fuse with label 125V/ 3A printed on the board, someone may have replaced the SMD with PICO fuse.
  • Mikeyboy2007
    replied
    Tom, I tried disconnecting each ribbon and still the same no picture. do i test the voltages on the point i have circled in red ?? and also where is the fuse on this board ?
    replied
    That's a samsung T-con.
    RUNTK.... is Sharp's prefix for LCD TV bits.
    I know some Sharp panels are having no picture failures.
    You can try disconnecting one of the t-con ribbons and see if you get half a picture, if so that confirms the panel is bad (try both ribbons)
    And pictures! Pictures!!!
  • Mikeyboy2007
    replied
    Originally posted by flocko
    Does it use the RUNTK5351TP T-con these are failing on this and other models big time and not cheap to replace, backlight on with sound but no picture Flocko
    the Tcon board is BN41-01678 and it says model is S100FAPC2LV0.3 if thats any use ??
    replied
    You can check at the fuse...
    and consider investing in a basic analog scope, they are available on eBay for sometimes less than £50
    (do not get a USB or "toy" LCD scope, they're useless; pick up an old, big, heavy CRT scope with 20MHz or more bandwidth and you can test a lot of things)
  • Mikeyboy2007
    replied
    First check the T-con board if it has any power, then look at the LVDS signal from the main board on a oscilloscope. Just flick the menu on and off on the TV and you should see a difference on the oscilloscope.
    how can i check the T-Con for power ? and also i cant check with oscilloscope as havnt got one
  • flocko
    replied
  • CapLeaker
    replied
  • Mikeyboy2007
    replied
    still get a backlight... is there any further testing i can do to determine if bad panel ?
    09-07-2024, 05:50 AM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Dodgethis
    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
    by Dodgethis
    Hello all,
    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
    09-11-2024, 07:39 AM
