Samsung LN5265FX/XAA -VERTICAL LINES
    I have a Samsung 52" TV that has multicolor vertical lines on the right side about 1/2" wide. As the set runs the lines disappear until only 1 green line remains. Occasionally another line will appear but will go away by touching the screen at the tip of the line. Do you have any ideas about the problem or how to fix it?
    Re: Samsung LN5265FX/XAA -VERTICAL LINES
    Tab bond fault.
    Screen is scrap.
    Sorry
      Will it get worse or is this something I just have to live with?
        You can attempt to use thermal pads to press the ribbon connections, 'Sometimes' you may have success but it is a tricky thing to do.
        Otherwise there is nothing else that can be done, When a panel dies that is the end of its life, It may or may not get worse
          Thanks for the input. It was free and I revived it by replacing the bad caps so - Live and let die.
            did you fix the vertical lines?
            my sony xbr2 had died on me. It was no pix no sound. change tcon board now it has sound but with vertical rainbow lines.
