Toshiba 40D1333B no back light.
  • zomi
    • Nov 2011
    • 505
    Re: Toshiba 40D1333B no back light.
    Interesting makes it even more of a bugger..
    Seems that the leds fitted are of a low quality looking at home many are failing.
    Coupled with the brickable main boards makes it even more of a minefield.
    shocking for a toshiba set costing a premium for the name..
    Ps. diodes gone on the inverter ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yeah I know just like the older inverters if it detects a change in the current eg bad bulb it wont fire, designed to fail basically. In some cases these inverters do fail but normally its a mix of bad led/diodes complete crap.
      • zomi
        • Nov 2011
        • 505
        Whats the easiest way to verify an inverter is good in these cases...
        As you have
        1. poor connections..
        2. flaky/ blow led/diode.
        3. inverter bad
        And I take in that order...
        awful awful desgin the way they have done it and how you get to the parts...
          It's not a Toshiba, it's a pile of Vestel garbage. Toshiba execs have taken their once good name and run it firmly into the ground. Sad.
          • Dang
            • Aug 2013
            • 440
            I've read somewhere that bad LEDs can be removed and then bridged to get the Tv working again, is that possible here?
              No - bridging LEDs will cause excessive power dissipation in the driver balancing circuit, leading to early failure. It may also cause dark/light patches to form.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                I agree, and the drivers on these need the current to be perfect or it wont fire.
                • zomi
                  • Nov 2011
                  • 505
                  #28
                  Any easy way to test an inverter,where the backlight as failed. ?
                  to rule out the inverter ?
                  • Dang
                    • Aug 2013
                    • 440
                    OK, so what is the best course of action here? could something be put in place of the LED to help balance the current, a resistor maybe?
                    • thoma
                      • Sep 2012
                      • 268
                      http://cart100.com/Product/38462740332/
                      http://www.iccfl.com/product_info.ph...ducts_id=10314
                      regards thoma
                        You can use 3.3V 1W ZENER if the LED current is 100mA, it will run quite warm so try to get the body of the diode to make contact with the metal chassis of the LCD panel and use heat sink compound, also make sure to put it in reverse of the LED'S POLARITY.
                        • Dang
                          • Aug 2013
                          • 440
                          Thank you, worth a try and quite helpful.
                          • riget
                            • Sep 2011
                            • 66
                            I have a sneaking feeling this is a TV with the 24V going to the panel, and the LED driver is inside the panel.
                            That's how the AUO panels in the 40L1333DB sets do it, and they use a very similar arrangement of parts.
                            Hi, I've got a 40l1333db with the same sound but no picture problem, my power board is different to the one on this thread, I opened the screen and checked all led's work fine.
                            The lower left black connector is giving me, 3v, 5v, and 24v so all seems good
                            The connector for the led's is on the right a white block with just 2 wires to power the led's, when the tv is on this gives just 2v, can anyone see where on the psu the fault could be?
                            Thanks.
                              When you say you "checked all LEDs work fine", do you mean you checked them with a multimeter/battery and made them all light up...
                              Or.... do you mean that you saw them all lit up (if so why are you checking the power supply LED voltage?)
                              • riget
                                • Sep 2011
                                • 66
                                Yes the fault is no backlight, the led's were checked separately.
                                  Any good clear pictures of the whole bottom side of the board?
                                  • riget
                                    • Sep 2011
                                    • 66
                                    I'll take a pic tomorrow, thanks.
                                    • riget
                                      • Sep 2011
                                      • 66
                                      I'll attach some pics, the best my phone can do.
                                      • Dang
                                        • Aug 2013
                                        • 440
                                        Thanks.
                                        As you have most probably already read, the PSU isn't the problem, at least not in my case, indeed this PSU has been used elsewhere now(a 50" Celcus) and has been working fine for a while now, my bet is a bad driver board or bad connections between the LED strips, some have actually soldered these together to cure the problem.
                                        • riget
                                          • Sep 2011
                                          • 66
                                          No mine is the psu, there is no driver board, the connector on the psu goes directly to the led's.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
