E320-A0 - Power LED Fades, Sound, Picture (Without Backlight) LED Issue
  • crepiduse
    • Nov 2010
    • 69
    Re: E320-A0 - Power LED Fades, Sound, Picture (Without Backlight) LED Issue
    Considering all I have is the main board and the led strips, no seperate driver, how would one test?
      The LEDs (I do not see any current limiting resistor on the strips) are connected in the series from what I can see, the return side of the LED (Cathode) is connected the DRAIN pin of the power MOSFET driven by PWM signal, the Source pin is connected to the Current sensing resistor, this junction point is fed to the LED driver IC to monitor the LED current to maintain constant current through the LEDs, another end of the sensing resistor is connected to return GND of the boost converter power supply.
      If the 10 LEDs in series then the total Vf is about 33V.
      BTW, if you have only one strip connected only, do you get any lights action?
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I would think he would have to jumper the output connector of the first strip to make a complete circuit. However if the sensing resistor did not knock down the 33 volts he would have to much current going through the five LED's.
          The Voltage is not really regulated, the current is regulated to maintain constant current (for steady lights) as the LEDs active resistance varies due to for example the temperature, the MOSFET and the sensing resistor and the feedback are used to maintain the current.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            This brings me to another question for BudM. Will the sensing resistor cause the unit to shut down if it gets to much current or will it just throttle down the voltage until the current is in the correct reading? If it just throttles down then if a person could not find a LED for the strip one could just jumper the open LED.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              I read that with the PWM and the drive circuit the duty cycle and the power mosfet inside the drive chip varies causing the supply voltage to be less for the LEDs. In this way they can dim for the ambient light.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                First the PWM at a giving voltage changes it duty cycle which lowers the DC current over a given time. Then the other example is the Chip that has the power mosfet inside conducts less which is controlled by the feed back circuit to the CPU and shuts down the available voltage.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  I believe they are changing the voltage to regulate the current. Instead of using the current to regulate the current. If the latter was the case the voltage would remain the same and the current would change by supply more current for a given voltage so if more LEDs were added the available current would increase and not the voltage.
                    For current to be maintain at constant, the active element in the circuit has to be constantly adjust due to change in the load resistance so basically the Voltage across the load will varies with the change of the load resistance to maintain constant current, in this case the MOSFET is the active element that is being used to maintain the current and the sensing resistor is being use to measure the current through the circuit.
                    As you can see that when we look at the Voltage output to the LED, the output Voltage is way high due to no load, if it is Voltage regulated, the Voltage would have been constant, so at no load or at high resistance, the output voltage will go up to try to force 100mA or what ever the constant current should be so it max out the output Voltage.
                    For example, lets say that you have 1A constant current power supply with 1 Ohm load, now if the load is changed to 2 Ohms, then the output voltage must go up to 2V., but if the maximum power supply output Voltage is only 10V, so when you put 100 Ohms load on it and it tries to force 1A through 100 Ohms, that will never happen since it can only put out 10V so the output will show only 10V (MAX OUT) and only 0.100A will be flowing through the 100 Ohms.
                      When you have two parallel load connect to the constant current source, if one load is open the power supply will try to force the current the existing 1 load.
                      I.E, two loads, 100mA constant current source, 50mA per load, if one load goes open, the power supply will try to force 100mA through 1 load that is still connected since its job is to maintain 100mA through what is ever connected to it.
                      You can connect variable resistor to output of the LED drive to see what range of the current regulation it has, and you will be able to see the relationship between the output voltage and the load, for example, some people will bypass the bad LED in the string, if it is well regulated current source then it should function fine, I will need to do the experiment myself to observe the results.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        So with the constant current in parallel. One would have to have a sensing resistor to each LED circuit to regulate total current in all branches and the cost would prohibit that from happening. Or one could monitor the total voltage in the parallel circuit. If the voltage increased that would mean that one of the LEDs went bad and the CPU could adjust for that and one could also monitor the total current to see if one of the LEDs shorted out and then shut down the circuit. So say if each LED was 10 ohms of resistance. 2 LEDs would be 5 ohms in parallel. And 3 LEDs would be 3.33... Ohms. Even if the LEDs did not behave like resistors one could put a limiting resistor in line with each LED to achive this effect. Then it would be possible to parallel LEDs with constant current.
                          In the parallel situation, the LED driver circuit goes into shutdown if one of the parallel string goes open circuit that is what I have seen in the panel with parallel connection (it is not really directly parallel since each string has its own MOSFET and sensing resistor).
                          You cannot really parallel the LED directly since not all Vf are the same, the one with lower Vf will light up but the one with higher Vf may not light up or barely light up, that is why you use resistor with each string of the LED you are doing simple parallel LEDs connections.
                          Some of the panel that has dynamic contrast will have like 8 drivers for the LEDs so they can do local dimming.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Thanks BudM for the info
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • Kingfreddie
                              LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                              by Kingfreddie
                              Ok.. this is the story:
                              Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                              This is kinda how it looked, just that mine were at the bottom of the screen:
                              09-11-2021, 01:57 AM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
