Philips 42PF3320/10 plasma white flashing
  • IMBack!
    • Apr 2015
    • 19
    Hi I have a Philips Philips 42 SD v4 plasma tv 2005 vintage, i dont know its history.
    Its fault is as follows
    At first:
    1. tv turns on flickers at aprox 1hz allmost white then black (see video).
    2. all rails are pressend and voltages are correct but there is alot of ripple (see picture 1 and picture 2) during the blink "on" phase on all rails, even the 5v and 3.3v logic rails.
    3. This ripple dissapears when the Y sustain is detached.
    Than sunndenly while measureing the voltages with just the x sustain attached somithing happend, sound made by the unit changed, a ployfuse on the power supply triggerd. No short was created by me.
    Now:
    1. If the X sustain is attached ve, vs go to 0v polyfuse triggers
    2. if x sustain is dettached everything is like before.
    what now?
    Addtitionally attached is a table with the measured voltages in different stages.
  • IMBack!
    • Apr 2015
    • 19
    Re: Philips 42 SD v4 plasma tv
    Actually the ripple is quite bad when every thing is unplugged from the power bord. Ho mutch ripple is acepatable on vs?
    • IMBack!
      • Apr 2015
      • 19
      Is some piece of information missing? the service manual identifys the tv as "42SD v4"
      the marketing name is 42PF3320/10
      the pannel and all major boards are samsung in origin.
      • IMBack!
        • Apr 2015
        • 19
        Well the x-board hat a blown fet. its in order again. dosent solve the other issue thogh
        • IMBack!
          • Apr 2015
          • 19
          I have switched the IPMS's on the y board with those on the X-board. the problem has not changed.
          If the logic flex cable to the Yboard is disconnected the voltages stabilze and a ysutain wave can be seen on the test points on the buffer boards. otherwise the ybaord cycels
          also a buzzing sound from the y board can always be heard
          • IMBack!
            • Apr 2015
            • 19
            1. Both y testpoints on buffer, shown on scope.
            2. Y board
            3-4. Y buffer.
            • IMBack!
              • Apr 2015
              • 19
              I tryed to measure Vsch. But i cant find it.
              The attached picture shows the Y-sustain connectors to the buffer.
              All the red highlighted pins are connected together. All the Yellow highlighted pins are also connected together.
              There is no voltage or waveform of any kind between the yellow and red pins nor is there any voltage betwen the blue pin and the other pins.
              all pins have a aprox +-200v square(ish) wave on them to ground.
              shloud Vsch be found between the red an the yellow pins? if no where is it found? If Vsch shloud be there what fault on the y-board might cause it to be missing?
              • IMBack!
                • Apr 2015
                • 19
                Re: Philips 42PF3320/10 plasma white flashing
                anyone?
                • tw2005
                  • Oct 2011
                  • 6458
                  can't help with the fault finding but there's a test pad marked VSCH to the left of R5135 and above D5020 near where that yellow transformer and large electrolytic cap is as you have the photo of the ymain orientated .
                  • tw2005
                    • Oct 2011
                    • 6458
                    what's going on with D5005 (unmounted from the heatsink) and the other D5004 with the screw half hanging out?
                    • tw2005
                      • Oct 2011
                      • 6458
                      IPMSs? I dont see any IPMs if your talking integrated power modules?
                      • IMBack!
                        • Apr 2015
                        • 19
                        ipms i ment d5005 and d5004. i need to resolder those they don't align with the heatsink. but they aren't getting very hot in the 1 minute test cycles im doing (tested with temp probe).
                        • IMBack!
                          • Apr 2015
                          • 19
                          Found somthing.
                          5v VCC is conneced to the yellow highlighted pin, but only 0.38v are present.
                          The regulator in red is responisble for VCC. It works, i powerd it up with a lab power supplya and a 0.5a load. According to its datasheet it needs 8-12V on the input pin. Its getting 0.5v.
                          Im tying to find where the input pin is connected to, the last point i can trace it to is highlighted in green. its a 4 layer board and i dont know where it goes after that. any hints?
                          • IMBack!
                            • Apr 2015
                            • 19
                            Vsch is bang on at 140v so thats not it, thanks for the test point. you have good eyes.
                            I also made a mutch clearer picture of the ysus board.
                            • IMBack!
                              • Apr 2015
                              • 19
                              well looks like the regulator U5012 (highlighted red) is suplying the 5v reg. its input lead and ground are shorted (highlighted yellow) but its fine out of circut. it seams to be directly connected to the transformer t5001.. its a dc-dc regulator this makes no sense
                              I think t5001 might be bad, how do find a replace ment? what dose w3-13t mean?
                              • vicvc
                                • May 2015
                                • 13
                                • south africa
                                u5012 is a 15v reg not 5.c5040(elec) to gnd(to the left on your pic).d5019 and r5134 to t5001
                                • IMBack!
                                  • Apr 2015
                                  • 19
                                  oh crap. while trying to remove the tansformer, to see the traces underneath, i broke 2 leads . I cant find a datasheet or anything on the transformer, it looks like this board is a gohner.
                                  yes i know i was refering to that the 15v output of u5012 drives u5010 witch supplys the missing 5v rail to the buffer.
                                  • STKR123
                                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                    by STKR123
                                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                    I wonder if re-flashing the BIOS might be of any use here.
                                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                    11-03-2024, 06:58 AM
                                  • celiabrown
                                    Issue with Plasma Philips 37inch chassis FTL2.1
                                    by celiabrown
                                    Hello guys,
                                    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                    Can someone has any symptom like this ?
                                    Thanks​
                                    05-09-2024, 10:56 PM
                                  • Keshenatech1
                                    LG 50PJ350 plasma blowing Y-Sustain board
                                    by Keshenatech1
                                    Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
                                    05-13-2020, 10:08 AM
                                  • KevM
                                    Philips Pus 436401/12 flashing backlights question
                                    by KevM
                                    hi had loads of help from this forum getting TVs back up and running but seem to be hitting a brick wall with this one.
                                    Backlights failed before Xmas so ordered a new set and after replacing them and putting the set back together was delighted to see it work for 15 seconds only for the picture to flash on and off and a quick look round the back confirmed the backlights were flashing on and off
                                    I have a steady 44v at +vled and a fluctuating 0v to 10v at -vled when the light start flashing, a steady Bl-on voltage and steady dim voltage.
                                    If i disconnect 2 strings of leds...
                                    02-04-2022, 09:40 AM
                                  • learnmore
                                    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                    by learnmore
                                    Hello Community!
                                    CASE DETAILS
                                    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                    Tried inserting firmware on USB and left it in for a few hours, but no change
                                    03-03-2024, 09:49 AM
