Toshiba 40L1333B blinking red/green power indicator
  • Dobsonov
    • May 2018
    • United Kingdom
    #41
    Re: Toshiba 40L1333B blinking red/green power indicator
    Thanks, I gave that a go but it didn't work. Also judging from the earlier comments this firmware is missing a bootloader. I tried the one provided by the Danish manufacturer of a similar model but no luck there either. There has been no indication of a power surge or the LEDs all popping out anything like that. Seems it just can't initiate anything. Any ideas of anything on the hardware side that could have done this?
    • ceedy
      • Nov 2008
      • 76
      #42
      Re: Toshiba 32w1333B blinking red/green power indicator
      Apologies for resurrecting this old thread .
      I've a 32W1333b TV with the dreaded Blinky red green LED ..
      Looks like it got the Corrupted firmware issue as I can Update the Files via USB ok, but not found a file for this TV that works .
      Read all the stuff I can find on the forum, and been playing about with 2 lots of files found on here .. from Reecyburger and russellhearn69, thanks Guys
      Admittedly both files for a 40 in screen .
      One gives a display with slightly dodgy fonts and an Upside down Picture.
      and the other gives a Blank screen only .
      I have also download the correct (32inch) single file from the Toshiba site , and renamed it to that of the successful( upside down) flash file but this gives a blank screen.
      Wondering if the usb_auto_update_A1 txt file might need editing , but this so far is a little outside my comfort zone
      any advice peeps ..
      Cheers
      Chris
      • zomi
        • Nov 2011
        • 505
        #43
        try these
        • ceedy
          • Nov 2008
          • 76
          #44
          Originally posted by zomi
          try these
          will do cheers ...
          Piccy of the PCB
          C.
          • ducky29
            • Dec 2015
            • 370
            • Europe
            #45
            I can get the correct firmware for you for 10$ if you are interested.
            • ceedy
              • Nov 2008
              • 76
              #46
              Thats another one of these ..LOL.
              See the crappy font too
              ta
              Chris
              • ceedy
                • Nov 2008
                • 76
                #47
                back again..
                Found this Rar of many files for the toshiba 32 inch . from a link by russellhearn69
                http://www.mediafire.com/download/hd...B_SOFTWARE.rar
                tried the first files ( Cat 79) files and its working ..
                hopefully the files may be of use to others ?
                Cheers
                Chris
                • dani502017
                  Banned
                  • Sep 2017
                  • 85
                  • Romania
                  #48
                  tell me the full code motherboard and panel to give you the right software
                  The right thing to do when it comes to TV software is to get the details about tv, mainboard code and panel (display)
                  • ceedy
                    • Nov 2008
                    • 76
                    #49
                    All sorted its seems .. not tested the freeview tuner yet tho '
                    Did check the board info with the assorted files but nothing matched up . so just did the first in the folder and voila !!
                    still thanks for the offer
                    Chris
                    • igor tsybuch
                      • Jun 2019
                      • 6
                      • Украина
                      #50
                      Помогите телевизор toshiba 48L1433DB такая же проблема мигает индикатор и не включается до етого помогало только витянуть с розетки и включить заново,7 месяцев телевизор в ремонте и никто не может починить,в чем причина?
                      • igor tsybuch
                        • Jun 2019
                        • 6
                        • Украина
                        #51
                        Originally posted by igor tsybuch
                        Помогите телевизор toshiba 48l1433db такая же проблема мигает индикатор и не включается до етого помогало только витянуть с розетки и включить заново,7 месяцев телевизор в ремонте и никто не может починить,в чем причина?
                        Помогите пожалуста
                        • OfficialReegz
                          • Jun 2019
                          • United Kingdom
                          #52
                          Hi Guys.
                          Wonder if you can help me with my issue here...
                          Very similar symptoms but I've tried flashing with no success.
                          Here is the specifics to help you.
                          Video: Click Here
                          • Diah
                            • Feb 2013
                            • 6374
                            Originally posted by OfficialReegz
                            Hi Guys.
                            before 6 years i got PSW leaked of Toshiba FTP server.. i downloaded all TV service factory firmware.i need search all my Hard DISKS DUMP.as soon i find them will uploaded on mega
                            update: sorry no L series only RL, TL, SL, UL
                            • OfficialReegz
                              • Jun 2019
                              • United Kingdom
                              #54
                              Thank you for looking though
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                #55
                                That would be great to have
                                We're talking about the BINs that go on the SPI flash SOIC chip, or the USB update ?
                                Feels like forever since I've messed with a Vestel...I used to know these things inside and out, but I've lost my touch and need a refresher
                                Wattevah...
                                • yokoono
                                  • Apr 2010
                                  • 486
                                  #56
                                  What display does it have? VES315??????????
                                  • krist0ph3r
                                    • Mar 2021
                                    • United Kingdom
                                    #57
                                    New here, and attempting my first TV fix: my friend's 49L3753DB. Firmware is not listed on Toshiba's site! Any idea where to look? Problem is exactly what others have described: red/green flashing power LED on front panel. The TV is also missing a remote, but the switch on the side should be enough I hope.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #58
                                      Have you looked through the EEPROM thread?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        #59
                                        Is the link to the file in post #47 still working?
                                        • mad_philly
                                          • Apr 2021
                                          • 11
                                          • United Kingdom
                                          #60
                                          Hey all,
                                          Glad I found this forum with this issue so well covered! I have a 49U6863DB with this problem, although it's intermittent. I cannot find any firmware for this model, only software from Vestel. I downloaded this and extracted to a blank FAT-formatted flash drive. Turned on the TV and inserted the drive. Media browser popped up and of course didn't recognise the files. Tried powering on with OK pressed but that didn't seem to do anything.
                                          Any tips for this model?
                                          Many thanks in advance
                                          • mad_philly
                                            Toshiba 49U6863DB blinking red/green power indicator
                                            by mad_philly
                                            Hey all,
                                            I have a Toshiba 49U6863DB with a blinking red/green power indicator, although it's intermittent. I went through https://www.badcaps.net/forum/showthread.php?t=45796 which is the same issue on another model.
                                            There are no online updates per the settings menu and I cannot find any firmware for this model, only software from Vestel. I downloaded this and extracted to a blank FAT-formatted flash drive. Turned on the TV and inserted the drive. Media browser popped up and of course didn't recognise the files. Tried powering on with OK pressed but that didn't seem...
                                            04-13-2021, 04:39 AM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
                                            09-06-2024, 05:27 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                            09-06-2024, 05:59 AM
