Toshiba 40L1333B blinking red/green power indicator
  • Dheano
    • Apr 2015
    • 13
    Re: Toshiba 40L1333B blinking red/green power indicator
    Thanks a lot, potentially saving me plenty of £££ here!
      I cannot guarantee it, but it LOOKS like this manufacturer uses similar parts in their TV:
      http://nsi-el.dk/software/
      Download MB9X file with product code "40LED6005" you may have to try both files to see which works.
      Note: I recommend editing usb_auto_update_A1.txt and commenting out the mboot stuff (prefix "#" on line) as the mboot is probably intact, and corrupting this will remove the one life-line you have (if corrupted, you would have to desolder mboot flash and flash it out of the TV, which requires equipment and soldering skills) - example:
      Code:
      #mboot
      #For pure mboot.bin upgrade, use below part
      #fatload usb 0:1 80400000 mboot.bin
      #spi_wrc 0x80400000 0x00000000 0x0120000
      Only issues - the Freeview will probably NOT work - as this is a Danish company - and I can't guarantee it'll support English language...
      You MAY be able to then upgrade firmware using the Toshiba procedure later, to convert it back into a "Toshiba"...
      • Dheano
        • Apr 2015
        • 13
        So if the Freeview fails the update from Toshiba would probably fix it?
        I can code so I've commented out the mboot stuff, cheers for the tips and help!
        Giving it a shot now, I'll let you know how I get on. I'm right in saying I need to hold OK on the remote control, right?
        • Dheano
          • Apr 2015
          • 13
          Just realised, got a spare freeview box upstairs.
          Currently upgrading, hope this works, thanks for your help!
          • Dheano
            • Apr 2015
            • 13
            Although this sounds impatient, anyone have an idea on how long this thing takes? It's been on for almost twenty mins, still flashing really quick.
              100MB file, could take a while I guess but 20min sounds too long...
              No penalty pulling out USB now, as long as mboot is not replaced, it will only leave it in the original condition. It's possible that it doesn't like that file.
              • Dheano
                • Apr 2015
                • 13
                Would replacing the mb90_en.bin file from nsi-el with the Toshiba one make a difference? I've since pulled the memory key and switched power off and back on. Issue persists.
                  Worth a try...
                  As long as you don't touch mboot you can't make it worse AFAIK... so it's worth trying whatever files you can.
                  Rename file to same name, though.
                  • Dheano
                    • Apr 2015
                    • 13
                    Same again. Assuming this is bricked then?
                      It looks like it will be a difficult fix unfortunately.
                      You could try looking at the UART output, if you have an RS232 cable for a PC.
                      That might inform as to where it is having difficulty.
                      I know you can open the image files as SquashFS partitions and fix things.
                      Maybe too much work for this "Toshiba" Vestel junk.
                      • lesnajair
                        • May 2015
                        • 57
                        #31
                        Hi Dheano. Sorry to jump on your post, but I have exactly the same problem and wondered whether you eventually found a fix?
                        Regards
                        Les
                        • jczarniak
                          • Oct 2015
                          • 179
                          Did you managed to fix it?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            He couldn't be arsed to update the thread which pisses everyone off. The fix replace the main board or buy the firmware kit off Ohm supplies for the Tv or if you have the tools and equipment read the old firmware flash off the old SPI Ic get an new Ic and reflash the firmware to that.
                            • jczarniak
                              • Oct 2015
                              • 179
                              Thank you.
                              • sordids999
                                • May 2013
                                • 2149
                                • uk
                                #35
                                Did anyone ever find the correct firmware to fix this issue i have a 40L1333B blinking red/green power indicator fault ?
                                also would the firmware from ohm supplies work ?
                                thanks
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  thanks
                                  Check through here mate I know theres some on here. Also maybe replace the Ic in the 17mb95 repair kit on ebay too.
                                  • sordids999
                                    • May 2013
                                    • 2149
                                    • uk
                                    #37
                                    Whats the difference with 40L1333DB and 40L1333B because ive just tried updating firmware with a 40L1333B but mine is a 40L1333DB and now i have no flashing standby
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Its the same and sounds like you updated it wrong You have to do it specifically as I stated in my other threads about these. Also only difference is the Lcd panels mate, B uses Samsung Lcd and backlight module and DB uses Samsung lcd and Vestel backlight module the firmware will be the same though panel info might be off but that is fixable. You updated it wrong likely
                                      • Dobsonov
                                        • May 2018
                                        #39
                                        Hi guys, I'm not sure if anyone is still checking this thread but I have a very similar problem. Whenever I turn on my tv with the remote it will flash green and red 5 or 6 times before staying red. If I press the power button on my remote again the same will happen but it will stay green. And it will continue like that. Prior to this there were no problems with the tv. Now it will just stay completely black at all times. I have tried leaving the tv off for varying amounts of time before powering up again: one minute, one hour, overnight. I have tried a couple of variations on the bootloader and firmware updates listed earlier in the thread.
                                        Does anyone have any other ideas as to what to try? If this is indicating a hardware fault - any ideas as to what to check out?
                                        Thanks for any suggestions you guys might have.
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #40
                                          You could try doing a firmware update. Information and files available from
                                          http://www.dl.toshiba.com/dtv/NA/GB/EN/40L1333B.html
                                          • mad_philly
                                            Toshiba 49U6863DB blinking red/green power indicator
                                            by mad_philly
                                            Hey all,
                                            I have a Toshiba 49U6863DB with a blinking red/green power indicator, although it's intermittent. I went through https://www.badcaps.net/forum/showthread.php?t=45796 which is the same issue on another model.
                                            There are no online updates per the settings menu and I cannot find any firmware for this model, only software from Vestel. I downloaded this and extracted to a blank FAT-formatted flash drive. Turned on the TV and inserted the drive. Media browser popped up and of course didn't recognise the files. Tried powering on with OK pressed but that didn't seem...
                                            04-13-2021, 04:39 AM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
                                            09-06-2024, 05:27 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                            09-06-2024, 05:59 AM
