failed samsung plasma panel?
  • grendal10
    • Apr 2015
    • 25
    Just wondered if anyone can help, ive got a 51" samsung ps51d550c thats faulty
    no picture or sound led light flashes, looked inside no blown caps but found a short on one of the chips on the buffer board and im assuming the y sus board has gone as well,the logic board led flashes every 6 seconds which seems to confirm a bad y sus board , if i remove the power cable from the power board to the y sus no difference if i remove the ribbon from logic board the led flashes every second and the screen starts buzzing like its trying to power up. After all that my main question is, when i tried to order the b y sus and buffer board from a lcd parts company i was told that the plasma panel on my series of tv will be defiantly have failed and will short the new buffer board and y sus, so if i replace with good boards it will do the same, is this true and if so is their anyway i can find out if the panel is bad or not before buying new boards?
    Re: failed samsung plasma panel?
    Is the panel cracked, even slightly?
    • grendal10
      • Apr 2015
      • 25
      not that i can see no
        If you have the tools, you can try removing just that IC. The TV should power up with a partial picture. This will confirm the panel is intact (small cracks may allow the panel to work, so you should still check carefully, including right on the edges.) If no cracks & pic works, then I'd try replacing the board. Sometimes, the buffer ICs do fail for no apparent cause.
        • grendal10
          • Apr 2015
          • 25
          thanks ill remove the ic and see what happens, can a screen thats crack free blow a buffer board or a y sus?
          • grendal10
            • Apr 2015
            • 25
            just had a close look with a torch and their is a hairline crack on the screen thank you for the help im abit gutted but you've save me time and money!!
              Darn - if anything is bringing these D-series Samsung panels down, it's cracks on the screen. Not sure what's causing them to crack, suspect it's some kind of thermal failure. It doesn't appear to be physical damage, at least.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Cooperr
                Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                by Cooperr
                I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                10-21-2025, 01:11 PM
              • alltvrepairs
                Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                by alltvrepairs
                I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                Any one met this problem in the past?...
                10-08-2025, 07:34 AM
                09-07-2024, 05:50 AM
