LG 42LD750 - only Lg logo thengoes black
  • domix
    • Jan 2014
    • 168
    • Slovenia
    #41
    Re: LG 42LD750 - only Lg logo thengoes black
    is this okej? what else i must to check or to measure to find a problem why not working
    thank for help
    • paulstef
      • Dec 2013
      • 724
      At least they are equal, i.e. they are probably not faulty.
      You will need to do a deeper analysis of the backlight circuit. For that you will probably need an oscilloscope. Do you have one?
      I would start trying to identify the backlight inverter controller chip, look up its' datasheet and walk my way through the circuit beginning with the typical application schematic usually contained in these datasheets.
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        #43
        I had this tv before, same power board and same problem, the LG logo was coming up then backlights where shutting off.
        • domix
          • Jan 2014
          • 168
          • Slovenia
          #44
          no, i dont have it. so then cant do anything :/
          @Mikeyboy2007, do you find the solution?
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            #45
            i ended up just replacing PSU., i now have another one with no power issue so i am going to try and use parts from both to get one working.. try the other forum members suggestions before spending money on a new board, i only purchased a new board as that is what the guy i was helping wanted me to do.
            • domix
              • Jan 2014
              • 168
              • Slovenia
              #46
              okey, than can i close it and wait on ebay or some else, if someone sell broken tv with working psu, i look around and its around 100$, it's to much
              • alikate36
                • May 2015
                • 3
                • espaƱa
                #47
                hello I have a similar problem, but I have nothing burned nor any swollen capacitor my lg tv 42LD750 not turn on, the red LED starts to flash but will not start, fuses are correct.
                possible solution?
                thank you very much
                • alikate36
                  • May 2015
                  • 3
                  • espaƱa
                  #48
                  possible solution?
                  thank you very much
                  solved! I was measuring voltage and note that had two pieces of the same reference q gave me a different extent, they gave good 24 v. which failed think 13 I've changed already on the first part q failed was this: BC 003 017 Everlight and replacement q have given me in the electronics store is: optocoupler PC817 the changed part is to arrow and is the twin of the circle.
                  but my English (google translator ...)
                  • alikate36
                    • May 2015
                    • 3
                    • espaƱa
                    #49
                    sorry photo
                    • Adriatic
                      • Mar 2017
                      • 23
                      • Slovenia
                      #50
                      • Adriatic
                        • Mar 2017
                        • 23
                        • Slovenia
                        #51
                        Hello.
                        First thank you for accepting me on this forum.
                        If someone can help me. I have the exact same tv. The previous owner (thru repair shop) did try to repair the PSU but failed. I got this tv for 40$ and now I'm trying to repair it myself. I'm a hobby / learning type.
                        However to the point. On the picture attached there is something missing (thought by the color it is a thermistor but not sure). Because of lacking schematics of this PSU board I'm almost blind and I can only guess.
                        If somebody can help me and check the type of missing element. I would be very
                        Have a nice day to all of you.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          Previous post also attached to
                          https://www.badcaps.net/forum/showthread.php?t=43901
                          • Ihandyrepair
                            4 red flash led 65X950G boot Sony and android logo but then black
                            by Ihandyrepair
                            HI guys
                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                            here is the issue
                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                            but then I get black screen and 4 red flash light at the front LED
                            but I get 3 led flash on the LED driver board.
                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                            so I tried...
                            07-11-2024, 01:45 AM
                          • jake-b
                            dell e6540 boots to black screen (no dell logo)
                            by jake-b
                            good morning all,
                            i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                            01-08-2024, 10:29 AM
                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                            09-12-2024, 02:00 PM
                            MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                            This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 01:58 PM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:00 AM
