LG 47G2-UG Horizontal Lines
  • djinn5150
    • Apr 2015
    • 7
    Hello all, having some issues with my LG 47G2-UG Google TV. I have persistant horizontal lines that seem to "fade" from left to right. Basically seems to be from left side to about middle of screen but maybe more in the 2/3's range, far right is clear as day. Theese lines are evenly spaced from top to bottom at about I am guessing few mm or maybe 10px. The are probably only 1 px thick. Based on what I have read in other threads this will either be a T con or a panel issue. Is there any tests I can perform to confirm one or the other? Really don't want to order a t con just guessing Thanks in advance
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: LG 47G2-UG Horizontal Lines
    https://www.badcaps.net/forum/showthread.php?t=39740
    Also of fault too please
    • newtothis
      • Mar 2013
      • 1556
      • england
      Just realized its an LED...
      Most likely bad panel... Give is a pic of just the screen showing the fault
      • djinn5150
        • Apr 2015
        • 7
        Hope these help, sorry for my haste and not helping you, help me. I have a video uploading to YouTube at the moment I will attach a link once it's processed. Thanks again
        • djinn5150
          • Apr 2015
          • 7
          Video Lg 47g2-ug: https://youtu.be/-ZUZHg_j78w
          • newtothis
            • Mar 2013
            • 1556
            • england
            Sorry but to me that looks like a panel fault, No doubt someone will concur
              I concur...
              Most likely the panel is bad.
              • djinn5150
                • Apr 2015
                • 7
                That's what I was afraid of but better knowing then throwing 50 bucks down the drain
                • djinn5150
                  • Apr 2015
                  • 7
                  Its a shame to only like 2 year's old
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    All too common these days
                    It is starting to look more viable these days for me to get a rebonding machine to repair the bloody things!
                    • djinn5150
                      • Apr 2015
                      • 7
                      Guess I'm in the market got any brand suggestions that are less likely to have a panel failure?
                        List of good TV brands:
                        Panasonic
                        Sony...ish
                        LG...ish
                        And Panasonic ain't superb with their rebadging of Vestel garbage in some of their model lines - should be ok for US sets though
                        Certainly avoid Samsung... LG is usually OK actually... not superb, but given a rather mediocre bunch they start to look alright.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          For a reliable set (If such a thing exists!)--I would look out for a TH-50PZ80/81 Panasonic--Old yes, a 1080p set but with high power cons,(500W--you'll need no room heating!) but at least reasonably reliable--Bonus it can be Fixed if it Does fail, and has damned site better picture than this LCD junk around today!
                          TELEFIX
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • Ihandyrepair
                            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                            by Ihandyrepair
                            Hi guys
                            I just started fixing 4k TV few months ago. so I am still learning a lot
                            I got this tv from friend complaint is ghosting or horizontal lines on image.
                            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                            then it started to show the ghosting white image.
                            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                            it has 3 thin small boards at the bottom of the...
                            12-05-2022, 04:18 PM
                          • ggil44
                            Sony XBR-65X750D Horizontal lines bottom of screen
                            by ggil44
                            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                            05-30-2023, 07:51 PM
                          • noisykid
                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                            by noisykid
                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                            12-30-2024, 07:15 PM
                          • noipi
                            samsung Oled 65 Horizontal Lines and Flicker
                            by noipi
                            I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                            10-14-2025, 02:11 AM
