HP PL5060N - Loud snap - very dim picture
  • smartjohn
    • Feb 2013
    • 116
    I bought this set for $50 and the owner said it quit with snap or bang. It powered up but had a very dim washed out picture. After checking some other posts and tapping around the set, I could get the picture back partially if I tapped the upper module (YPPD-J015C) of the Z Sustain (Z_SUS) board. I replaced this module back in September, 2014 and the set worked great for 6 months at my son's house. He called me just before March Madness and said, "Dad help! it died again!"
    My suspicions were correct as it was the same failed YPPD-J015C module on the Z_SUS board. Because I believe this is a heat related failure and I am not one to keep fixing a repeating problem, this time I decided to mount a 12 volt fan on the heat sink. The set uses the LG part # 6870QZC004C Z_SUS board. Here's my YouTube video on the fix for the module: https://youtu.be/F4hvDi18AzM I hope this helps someone else looking here for a more permanent solution !!
  • smartjohn
    • Feb 2013
    • 116
    Re: HP PL5060N - Loud snap - very dim picture
    So this set has blown the YPPD-J015C module on the Z-SUS board at least 3 times. Last time replaced the complete Z-SUS. The set ran OK for about 15 minutes and then went dim but now it has a wide vertical bar. I am reading this points to the Y-SUS or buffer boards. I tried isolating each buffer I still have the vertical bar on 1/2 screen. I then replaced the YPPD-J015C on the Y-SUS. Now the power supply is cycling on/off with a click every 5 seconds. I can see 5V and 9V come up then drop. I never get Vs, Vsus or 24V to come up. any ideas?
    • smartjohn
      • Feb 2013
      • 116
      I finished this on another thread: https://www.badcaps.net/forum/showth...984#post630984 Turns out I replaced the Y-sus IPM with a bad YPPD-J015C module. AND the MOSFETs were blown on the lower buffer board. Details at the end of the quoted thread. I really like these TV's for the picture quality. I'll keep nursing this one on as long as I can!!
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • CyberPhoenix
        Issue with picture quality of Sony bravia TV
        by CyberPhoenix
        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
        01-22-2024, 02:08 AM
