LG PDP 50x3 MAL Discharge Trobleshooting
  • AncientOne
    • Jul 2015
    • 6
    Dear brilliant experts,
    I am stuck troubleshooting an HP 5060N TV, fabricated in 2006.
    It uses an LG PDP: PDP50X3R010
    A friend gave it to me after it broke. Over a period of two weeks the symptoms went from first appearance, to intermittent appearance, to appearing at all times.
    When the fault was intermittent, the TV picture would start out perfect, then after a while the entire screen would show the symptom as in the pictures in the blink of an eye. Then, after turning the TV off and letting it rest for 15 minutes, it would start up showing a perfect screen again, only to fail after a while.
    Now, when I turn the TV on, it always goes through the same sequence of images, similar to those in the pictures. I imagine that it is looking for a signal source. When I press the MENU or INFO buttons, different images are displayed. This leads me to believe that the TV is attempting to display specific screens, but that the image is messed up.
    I have read the information in the LG PDP model service manual, and this type of image seems to be what they describe as a MAL discharge problem.
    Unfortunately, they say that it could originate in several places: The two Y Drive boards, the Y sustain board, the control board, corrupted software on the control board, or the z sustain board.
    Can you assist me in identifying the faulty board(s) and possibly even the faulty component?
    The specific boards are:
    6871QCH059B CTRL HT50065A009059
    6871QYH039B YSUS
    6871QDH088A YDRVTP
    6871QDH089A YDRVBT
    6871QZH044C ZSUS
    3501Q00200A REV A S/N SO06516334 SONY Power Supply
    Many thanks.
    Yours in enthusiasm,
    AncientOne
  • smartjohn
    • Feb 2013
    • 116
    Re: LG PDP 50x3 MAL Discharge Trobleshooting
    I have this same set and am working on a similar problem. The large vertical white bar usually points to a problem on the Y-sus board (large board on the left side) OR the two buffer boards (with flat ribbon cables). I suspect my set is experiencing a problem on the Y-sus. When the set is on try, tapping on (with something insulated!) the two large aluminum heat sinks on the left side (facing the rear). These are the IPM modules which almost always are the problems with these TVs. I have had the ones on the RIGHT SIDE fail also. You may want to give those a light tap as well. good luck! I let you know if I get mine working also.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      MOSFETS on Buffer-Board S/C.
      There's three or four, you'll find one short--best replace the lot.
      TELEFIX
      • smartjohn
        • Feb 2013
        • 116
        Yep, sure enough, the bottom buffer had all 3 shorted. 46N15 N-Channel mosfet 150V 45.6A. I pulled the lower board and I am stilling getting the power supply cycling, so I guessing something is still bad on the Y-sus. I replaced the yppd-j015c IPM but not the other one. What should the resistance be on the Vs line to ground?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          many K ohms after caps charge...
          TELEFIX
          • smartjohn
            • Feb 2013
            • 116
            Great news. I went back over my changes and double checked the yppd-j015c I had replaced on the y-sus board thinking this was the vertical bar problem. Turns out the module i used was now shorted. I replaced it with the one I pulled and Bingo! I got the upper half of the screen working perfect! I replaced all 3 of the 46N15 MOSFETs on the lower buffer board (6871QDH088A). I bought the non_SMD version and tweaked it to fit. (they were a buck cheaper!)
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Good work
              • redwire
                Making a capacitor discharge tool
                by redwire
                I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
                Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
                His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
                Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
                06-18-2023, 07:09 PM
              • shagster
                Capacitor Discharge Rate Testing!
                by shagster
                Hi, I have 2 identical capacitors from an old scope I'm trying to get running.
                Both caps measure ok in ESR and Capacitance values imo.
                Data sheet says tolerance spec is -10 +50%. And these are way under that.
                Both of there original values are marked as (430uf 200vdc).
                After ~40 years, they now measure 485uf and 465uf. Well under the +50% tol.
                Anyway I charged them up to 24 volts dc and discharged them slowly down to 10 volts using a Digital Multi Meter. Funny thing was one of them just took over 4 minutes to discharge down to 10 volts. And the...
                08-24-2023, 02:55 PM
              • Keshenatech1
                LG 50PJ350 plasma blowing Y-Sustain board
                by Keshenatech1
                Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
                05-13-2020, 10:08 AM
              • angelos
                LG 42" Plasma Display Model 42PT350R
                by angelos
                Hello Guys,
                I am not familiar at all with plasma tv's but i tried my luck anyway since business is so bad. We gotta try, right?
                Anyway, the original problem was a tv clicking and not starting due to a short circuit on the Z-Sustain board (on the right side from the rear).
                I found two transistors shorted (30F123) and changed the gate driver ic's as well. I think they were FAN73711. I soldered for dry joint on power supply, Y-Sustain and Z-sustain. Started up the TV and the short was gone so i had an image but.....
                Lots of colorful speckles on the image and also there...
                05-04-2024, 11:01 AM
              • tesnic
                HP Omen 15-ax014ns - Don't charge or discharge battery!!
                by tesnic
                Hi community! I've a strange case.. Laptop HP Omen 15-ax with 11,55V new battery that dont charge or discharge. The battery coil with the battery connected ia 12,25V. All mosfets seems ok, i verify dont exist any short.... The laptop power on OK, even only with battery but it dont charge. I verify the volatges on BQ738H and it seems ok....i read the 2.2.3. Low voltage on battery charging rail​ post, but i dont be able to found the issue... Any idea guys? Thanks a lot!!!!...
                03-11-2024, 06:32 AM
