Panasonic Plasma TC-P54S1, Two Problems
  • Sidster
    • Jul 2014
    • 10
    Panasonic Plasma TC-P54S1 - Two Problems:
    Problem 1 - No Sound On Only One Channel.
    We get our TV Channels 'Over The Air' and all the channels are Digital. We use the built-in TV Speakers, no external speakers. Never had a problem before. Two weeks ago a new channel became available and we added it. Here is the Problem. It has no sound. It will show the Closed Captions but no sound. All the other channels on the TV have sound and this new channel has no sound. All the other TV's in the house, the new channel has sound. We have hit the SAP button and it only shows "Audio track 1 of 1" and no matter how many times you hit it, it does nothing. When you hit mute, the closed captions appear. Turn off Mute and it is as before, no sound. Have done numerous channel scans and same as before. No Sound on just that one channel.
    Anyone have any ideas?
    Problem 2 - Just today while watching a movie, a barely audible spark was heard and the image shrunk to only the center third of the screen. Both outer two thirds were completely black. If you were to divide the screen into three identical size vertical sections, the left and right sections were black. The middle section, the entire image was there. Squashed together but there. It lasted about 2 seconds and it went back to normal. Has not done it again but, if anyone has an idea what it could be, would just as well prefer to fix it now before it happens again or worse, becomes permanent.
    This Forum was great in helping repair this TV previously. Hopefully someone has an idea or the solution.
    Thanks!
    Re: Panasonic Plasma TC-P54S1, Two Problems
    Problem 1 sounds like a compatibility issue - probably not much you can do except invest in an external DTV box.
    Problem 2 is not a fault, it is the broadcaster sending a signal indicating the picture should be displayed in 4:3 instead of 16:9 ... Likely someone pressed the wrong button in the studio.
    • Sidster
      • Jul 2014
      • 10
      What would the compatibility problem be? TV is digital tuner and all stations are digital? It is only one channel that has no sound. All the others work perfectly. Would it be the tuner itself then?
      The shrinking screen happened again. It is not 4:3, we were actually watching a program that transmits in that format. It shrunk to only the middle third and then back to the normal 4:3. And, it happened after a spark sound on the TV. What board controls those three sections is what we are trying to find out so we can repair it.
      • Sidster
        • Jul 2014
        • 10
        Both issues solved. Defective parts.
          What parts were defective?
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • Hoyhoy
            Panasonic 60" plasma, white screen with sound
            by Hoyhoy
            I have a Panasonic TC-60PS34 60" plasma, built 5/2011. Periodically getting white screen (like looking through cheesecloth), with sound, when turning on. Turn off and on a few times and it finally works normally. Tried cleaning back, changing cables and inputs, unplugging unit, etc. Seems to be happening more often and harder to get it to work. I did notice that it usually clicks when turned on (red light comes on, no flashing) and clicks when I turn it off. When I turn it on and get a white screen, I notice that it does not click. When it does click when I turn it on, it seems to work normally....
            01-07-2021, 01:38 PM
