Vizio E422vl lightning damage
  • CapLeaker
    Leaking Member
    • 8225
    Re: Vizio E422vl lightning damage
    it should. post one after the other and remember the size of it, I think there is a limit.
    • johnp1214
      • Apr 2015
      • 21
      Every time I pic choose file it does nothing. It's weird
      • CapLeaker
        Leaking Member
        • 8225
        Without seeing it kinda hard to tell, but I think there are 2 problems. One is the panel itself and the other being the board, from what you are telling me.
        • johnp1214
          • Apr 2015
          • 21
          Got it
          • CapLeaker
            Leaking Member
            • 8225
            try to squeeze and twist the frame a bit. top, bottom, left and right.
            • johnp1214
              • Apr 2015
              • 21
              Ok one sec
              • johnp1214
                • Apr 2015
                • 21
                No changes
                • CapLeaker
                  Leaking Member
                  • 8225
                  bad panel... and a bad board.
                  • johnp1214
                    • Apr 2015
                    • 21
                    Expensive fix?
                    • CapLeaker
                      Leaking Member
                      • 8225
                      if you have a bad panel, the tv is going to be usually parted out. It is not economical to replace the panel.
                      • johnp1214
                        • Apr 2015
                        • 21
                        Ok any other ways to determine bad or good panel?
                        • CapLeaker
                          Leaking Member
                          • 8225
                          buy a new board or swap stuff around from a working tv. Vertical big lines and colorful singe lines usually is the panel. If you can't get rid of that by squeezing, twisting the frame, or by touching individual tab bonds, there is nothing you can do to fix the panel in a condition like that. So that is your last option... play with each individual tab bond.
                          • johnp1214
                            • Apr 2015
                            • 21
                            Ok. It's real loose due to screws being out so that could be it
                            • CapLeaker
                              Leaking Member
                              • 8225
                              no. there tabs are glued to the panel. so sometimes the glue lets go. if you find the offending bonds, you can shim it buy putting something on top of it. So when the frame is on it, the tab bond gets pushed or held down. I am thinking here like a piece of rubber or foam, rolled up tape etc. But if you can't get rid of that, then there is something internally in the LCD itself.
                              • CapLeaker
                                Leaking Member
                                • 8225
                                put tab bond failure into youtube and watch a few videos.
                                • johnp1214
                                  • Apr 2015
                                  • 21
                                  Ok ty I will try that. Ty for quick responses. I'll let you know what I find out
                                  • CapLeaker
                                    Leaking Member
                                    • 8225
                                    good luck
