Vizio E422vl lightning damage
  • johnp1214
    • Apr 2015
    • 21
    My friend gave me this t.v. after it was hit by lightning. No burn marks and no blown capacitor. T.v. turns on and off fine. But the screen is completely white with black and colored vertical lines. Any advice? Tried posting pic but for some reason it won't work.
  • johnp1214
    • Apr 2015
    • 21
    Re: Vizio E422vl lightning damage
    Here is pic attempt https://www.badcaps.net/forum/attach...6&d=1428012875
    • Hamie
      • Apr 2014
      • 1383
      Probably bad panel.
      Unfasten one of the tcon ribbons and see if you get a picture on 50% of the screen.
      • johnp1214
        • Apr 2015
        • 21
        Ok I will try that shortly. Thanks. Will post an updat
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          Originally posted by hamie
          probably bad panel.
          +1
          • johnp1214
            • Apr 2015
            • 21
            I just unplugged tcon ribbon. I got half my screen back. That mean a bad board?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              do the other one and see if it switches sides.
              • johnp1214
                • Apr 2015
                • 21
                Ok one sec
                • johnp1214
                  • Apr 2015
                  • 21
                  No it went all black
                  • johnp1214
                    • Apr 2015
                    • 21
                    It tried to retain some white and colored vertical lines but the black slowly crept up and covered it
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      aha. so you had only the other one ribbon cable plugged in and all went black?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8327
                        sounds like you got 2 problems. the tab bonds on the panel and the board.
                        • johnp1214
                          • Apr 2015
                          • 21
                          One sec tho.was I supposed to have both unplugged or switch in and out?
                          • johnp1214
                            • Apr 2015
                            • 21
                            No both were unplugged the second time
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8327
                              with both unplugged it should be black. Plug in the left cable with the right unplugged and then the other way around.
                              • johnp1214
                                • Apr 2015
                                • 21
                                Yes it Did switch. Sorry for confusion
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8327
                                  with one of the cable combination you got a half screen. Did the vertical color lines disappear or is it that where the screen retains some white and color lines and the black is creeping up?
                                  • johnp1214
                                    • Apr 2015
                                    • 21
                                    Lines disappeared. On half of it. Then switched sides when cables were switched
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      make pics please... a pic sez 1000 words.
                                      • johnp1214
                                        • Apr 2015
                                        • 21
                                        Do you have an email. For some reason it won't let me post a pic
