Vestel service menu adjustment
  • notallbad
    • Oct 2012
    • 1190
    Sorry, not been here for a while and probably not the right place for it but I am at a dead end with this and I'm sure someone here knows the answer.
    The tv works fully as far as I am aware but I am unable to change many of the settings in the Service Menu via Menu - 4 7 2 5.
    2 access codes work (4725 and 1461) which give access to the same service menu and 7935 to Hotel TV menu.
    Technika 19" LCDDVD19-918 Vestel 17MB25_v33f
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Vestel service menu adjustment
    Set must NOT be on DTV or you'll not access service-mode. Select any other input....
    TELEFIX
    • notallbad
      • Oct 2012
      • 1190
      Thanks, but the problem is not being able to get the service menu up but not being able to change settings. Very few are in bold indicating they can be altered, most are shaded out. Perhaps I am missing something simple.
      Also I do not need to enter a password when accessing the service menu, perhaps this is the problem, not accessing it with the correct code that then requests a password?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        What settings do you want to change--and importantly--Why?
        TELEFIX
        • notallbad
          • Oct 2012
          • 1190
          This model has a USB and SD card slot but am unable to get movies to play, it just views photos and plays music.
          I am aware that this model may not be abe to play video but there should be a menu accessible for adjustment just like LG etc...
          • notallbad
            • Oct 2012
            • 1190
            Anyone?
            • notallbad
              • Oct 2012
              • 1190
              Looks like this has everyone beat!
                Decoding video requires additional processing power. The TV might not support that. In particular it requires a video decoding engine and more RAM on board.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Err--No, Not really--It ISNT Faulty! We deal with Faults rather than Hacks!
                  You are trying to make it do something its not made to do--Thats called a 'Hack'! It requires additional software and hardware facilities to stream/decode video from USB sticks that this set doesn't have....
                  How you would Modify (Hack) such a set to do that you would need to investigate. Best start I could think is to compare to the Closest Vestel that Does stream from USB...
                  --Then again--Its a bloody VESTEL heap of Vomit!--Why Bother!!
                  TELEFIX
                  • notallbad
                    • Oct 2012
                    • 1190
                    Yeah, have to agree, these are complete crap to work on.
                    As I know other tv's can be modified in sevice mode to playback video I just thought it may be possible with this one but I'm not about to go all out over it afterall its only worth a few quid so not worth bothering with.
                    Samsung / LG much easier!
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      Hi guys im wondering if there is a way to rotate the screen in service menu ? accidently updated wrong firmware and now screen is upsode down.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        Are you still able to update firmware? if so get the right one.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          i done an update through USB. but now trying to revert back to original firmware V.0.4.7b
                          • heavymachines
                            • Mar 2011
                            • 1028
                            I could be mistaken but i believe you have to go same version or newer can't go back unless you have a cheap usb ic programmer to directly flash the ic. you can find them on eBay for like 14 bucks.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              ahh ok, i cant seem to find the firmware anywhere so will probably order new board.
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                              • tusiime
                                How to access Vizio m652i-b2 service menu
                                by tusiime
                                The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                                So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                                Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                                09-15-2023, 09:57 AM
                              • l3emarsh
                                panasonic vestel tv turn on alexa in service menu
                                by l3emarsh
                                i have a panasnic vestel tv and need to turn on alexa option using vestel software programming, using usb stck to reprogram software via tv usb port onced changed
                                Please help me as i cant remember how to do it.
                                all help is greatly appreciated
                                01-02-2022, 10:50 AM
                              • sohail5307
                                I need how to open this Dell service menu option in dell latitude e6420
                                by sohail5307
                                I need to open service menu of Dell laptops like image in attachment
                                Ignore my English
                                I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
                                01-13-2023, 05:56 AM
                              • Daniel Valdez
                                Samsung UN70RU7100K halfway bricked after messing with service menu
                                by Daniel Valdez
                                Dear All,
                                FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
                                12-06-2024, 06:56 PM
