how to test lcd led backlight?
  • keeney123
    replied
    Re: how to test lcd led backlight?
    I believe the static breakdown voltage of transistor with a silicon base are between 2500 and 4500 volts. This voltage can be created on a person walking across a wool carpet in low humidity. More fragile low current uni-junction FETs can be taken out with 100 volts static. This can be caused by rubbing a probe (in this case a medical research probe) against a the back of a plastic covered chair. BudM I like your new design it has promise.
  • Peter Chiu
    replied
    By the way, The CCFL tester exactly the same one in this video
    he already open .....Me too, will take picture ......tomorrow......
    https://www.youtube.com/watch?v=sfVkRiDGewA
    Picture 1 ...I test with original Samsung power supply @ 1us so it's about 2Mhz/374V
    Sorry, should be 1/(1us*4)=250kHz stead of 1us*2= 2MHz oh... sorry, my bad!....
    replied
    Open it up to see what are inside that tester. It is still too dangerous due to high Voltage out put.
  • Peter Chiu
    replied
    Very good suggestion ! That will be more accurate.
    I need to modify my CCFL tester to veritable HV . Maybe from Oscillator or input supply voltage.
    replied
    "use total current to estimate how many LEDs in one section" current draw will not tell you how LED or diode are in series, its the total Vf that can give estimate how may active device is connected in series.
    You can easily prove that using 6 Diode in series with small current limiter resistor then measure the total Vf for the 6 diode, you should see around 3.6V, please notes that Vf varies with If.
  • Peter Chiu
    replied
    Picture 6 Just light up 1 LED
    I did try directly contact just one LED still OK . In reality, the brightness isn't bright enough.
    The CCFL tester should use 2A 12v but I use 1A 12v( next time put a 3A/30v power supply or (a LM317 adj-voltage IC) will be fun.
    .......arcing from the tip of the CCFL tester to the LED connecting wire......
    That's why did not burn ,I use (the distance of the gap) as the current limitation.
    Next project 1:
    use total current to estimate how many LEDs in one section.
    Next project 2:
    Put a HV diode on the tips of the CCFL tester ,To distinguish + section's LEDs or -section's LEDs
    By not open the LED screen and we will know the answer (total number of the LEDs and how many sections LEDs the LED screen has and each connector wire's funtion? )....
    replied
    Pic 7: https://www.badcaps.net/forum/attach...1&d=1427996444
    I am surprised that you did not damaged at least the input circuit of the scope.
    I see that all the pictures show arcing from the tip of the CCFL tester to the LED connecting wire, is that right? And if you make the tip to have direct electrical contact to the wire, then did you damage the LEDs?
  • Peter Chiu
    replied
    I know, I got too excited, my pituitary give myself too much morphine.
    As a ADHD-senior citizen-electronic enthusiast I apologize for my misbehavior.
    Ok.... let's rock ........
    The LED Screen divided to two sections top 3 line LED strips, bottom 4 lineLED strips.
    Picture 7 The CCFL tester @20us so 50khz- sine wave-voltage out of my scope's range.
    Picture 6 Just light up 1 LED.
    Picture 3 only connected the CCFL tester black ground wire.
    Picture 4 light up all the LED screen.
    See in the picture, I cut my hand.......so I am in deep (The Moody Blues).....
    ........to be continued.........
  • Peter Chiu
    replied
    This is better than (The Most Unbelievable event in the universe)...The Big Bang
    Oh......... My sweet Lord............George Harrison......
    https://www.youtube.com/watch?v=HI8XY5BX_CE
    Even I hammer down one LED
    They still light the rest LEDs ....BY high voltage jumping?.....(in picture 2)
    ......Should I hammer down more LEDS and give back the report.......
    After about 20 mins
    Oh ......YYY...E...SS....Yes......Yes....... (in picture 3)
    .................We Are The Champions............................Queen..............
    https://www.youtube.com/watch?v=04854XqcfCY
    Tomorrow's project:
    Test different kind of LEDs back-light ( direct refection) screen...........
    replied
    White LED Vf (Junction Voltage) is between 3~4V range. Vf range depends on the current, so the LED Vf chart spec.
    http://www.maximintegrated.com/en/ap...ex.mvp/id/3070
    Typical silicon diode has Vf of 0.6~0.7V
    Is that arcing in picture #2?
    Check the current draw.
  • Peter Chiu
    replied
    After 4 hours research.... still no answer.....
    1. Why did not burn out the LEDs which I think so too.
    2.When any side of LEDs section, connected to the CCFL tester's ground will light up.. ........ Is the leaking voltage from real ground ,enough to breakdown the PN junction 's Bias voltage 0.56v
    http://en.wikipedia.org/wiki/P%E2%80%93n_junction
    there is a non-linear relation between voltage and current as shown in the picture ,In region 1, there are free ions that can be accelerated by the field and induce a current. These will be saturated after a certain voltage and give a constant current, region 2. Region 3 and 4 are caused by ion avalanche as explained by the Townsend discharge mechanism.
    Saturate certain voltage and give a constant current.... may be this is the answer..?......
    I can light up LEDs with + - or - + means non polarized....or is the CCFL tester actually is AC (I mean no HV dieodes inside , need to open the Tester to find out ???
    ........un....FIN....
  • Alastair E
    replied
    Originally posted by Peter Chiu View Post
    ....... I see that the CCFL is lit up partly on one of the winding. The good winding will light the lamp brightly. I remove the transformer, and sure enough, it has burnt winding.
    So this is a new trick for finding bad inverter transformer.......
    ? Aurora ???
    Exactly happen to me!!! This phenomenon can apply to (the LEDs section) too..... Amazingly.... the power of the nature....probably we can use proton or electron to light up LEDs.....or tasla ball or maybe super NOVA comic rays.......or just close to {Electricman-2} will light up the LEDs ....I knew electric static will light up fluorescent light, when I was a teenage, I hided in the cloth closet, used wool sweater to rub the tube ...and it light up.......
    The vacuum - gas or mercury filled -CCFL-or neon light... I knew that already.
    But for a semiconductor- solid state- PN junction-LED, I just learn today.
    Err--
    Wot on EARTH have You been smoking tonight!!--Some of Heisenburg's finest I reckon
  • Peter Chiu
    replied
    ? Aurora ???
    replied
    High Voltage probe:
    https://www.badcaps.net/forum/showth...x+dx-40l261a12
  • Peter Chiu
    replied
    I did not know ,U can light up CCFL light buld.... Good....Good .... useful Tips
    Because neon lamp too small to find it... all the time, then I look at the red light on power stripe,I know I find one,but .....too much effort to.......Thank you very much...
    May God bless America.
    Next project:
    How to use EXT(external) PWN signal to do the LED dimmer control........and use as LED screen tester II.......
    replied
    "....This is fun.....you can light up almost all LEDs , by maneuver the distance( not discretely touch ....near then move away ).
    playing with ..... the arc.....the Plasma.......{ feel like.... Nikola Tesla play with his Tesla coils....}" That radiated high frequency AC will light up Fluorescent lamp but not the LED.
  • Peter Chiu
    replied
    Finally, I have a adult's toy can play around..
    ....This is fun.....you can light up almost all LEDs , by maneuver the distance( not directly touch ....near then move away ).
    This might not to be the conclusion!
    The anwser to (how to test lcd led backlight?) is ........give it a.... [shock]......
    Next project 1: Modify the CCFL tester's resister try it for ( adjustable wattage)....be more safer....make my own LED Tester (zapper).....commercial mass products....
    Next project 2:
    Use old TV Flyback or microwave oven HV transformer plus a air compressor .....make a mini-plasma cutter.
    replied
    This is what I am experimenting with. The switch can be added for using Voltage Doubler mode or not. The OSC can be the 60Hz power line frequency.
    replied
    Originally posted by Alastair E View Post
    Well--It would blow up!
    CCFL's commonly use several Thousand Volts to Strike, and applying several thousand volts to a string of silicon diodes rated for only a few hundred at most will have the obvious result!
    DOH!!
    +1, beside the typical inverter transformer can only deliver about 5~8mA (at 8mA running voltage of 1000V = 8W of power for the lamp, equivalent load resistance of 125K Ohms), strike Voltage is 1500~2000V so yes, it will blow up.
  • Alastair E
    replied
    DOH!!
