Test dusplay "backlight only" A1297 macbook pro 2010
  • marce002
    • May 2018
    • 316
    • Argentine
    Hi
    I have image but no backlight. Fuse is blown. I think the display is faulty or cable lvds.. but not shorted last 3 pins in connector to GND
    .. Can I test the screen backlight only unplugged from motherboard with 32v at those pins? (Expecting to see a backlight only)?
    Marcelo J
  • ACS-Repair
    • Feb 2021
    • 204
    Re: Test dusplay "backlight only" A1297 macbook pro 2010
    You won't see any operating screen voltages if the screen is disconnected. Check for shorts at the screen connector for backlight with the screen connected (no power obviously) and disconnected to make sure there is little or no difference. Replace the fuse once confirmed to check for proper voltages.
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • Constantinos
      Macbook Pro A2442 820-02098 No image but has backlight
      by Constantinos
      Hi all
      I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
      He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
      Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
      Obviously, he decided against this and gave it to me so that I could have a crack at it.
      From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
      08-24-2024, 09:48 AM
    • francescoranchi
      MacBook Pro A1909 LCD (no backlight)
      by francescoranchi
      Hello Everyone,
      I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
      I would need just to make sure that what I know/my reasoning is correct:
      - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
      - Seller confirmed its a LCD issue, and not an issue with the...
      12-04-2023, 06:46 AM
    • tommy97
      Apple MacBook A2337 - No backlight
      by tommy97
      Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
      The laptop was tested with fully working screen.
      PP5v_BKLT_A/B 5V
      PP5v_BKLT_D 5V
      PP5V_S2 5V
      PP5V_SW_LCD 0.4V
      P5VS2_PWR_EN 1.8V
      P5VS2_BST_R 8V
      P5VS2_SW 5V
      PPBUS_5VS2_VIN 5V
      PPVOUT_LCDBKLT - Doesn't short 0V
      FP800 - Both sides 12v
      BKLT_EN_R & BL_PWR_EN - around 1.8v
      LP800 0.014V On both sides (should be 12? / no short)
      UC300 & UP800 Replaced...
      12-02-2024, 08:26 AM
    • rcanpolat
      M1 MacBook Pro 2021 A2485 - No backlight display
      by rcanpolat
      I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
      Here’s what I’ve observed so far:
      • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
      • I did some basic resistor
      08-24-2025, 02:16 PM
