Re: how to test lcd led backlight?
? Auto-recovery LED screen ? Resettable Fuse ? Auto-bypass LED?
ST has LBP01 part can bypass any defected LEDs
Benefits
■ Keep LED strings on in case of LED open mode failure
■ Reduced maintenance cost
■ Increase lifetime of the lighting system
https://cdn.badcaps-static.com/pdfs/...34696944c0.pdf
But, new LED TV used 2000 LEDs to make more brighter LED screen. I predict ( Auto-bypass LEDs will be use to build Auto recovery LED screen) in the future !
(I mean, LED will build in bypass circuit in the chip which just two more diodes. )
Tips: So next time don't put a cooper wire cross the defect LED put a diode.This allows the right amount current to flow through the other LEDs.
Yes that is where standards would work.Leave a comment:
If you want to use external constant current power source to drive the LED string then the strings are no longer connected to the LED driver board) so there is need to have any power to the TV at all since you are just testing LEDs.
The harder part is to figure out how the strings are connected together and which wire is the Anode and which wire is the Cathode if the panel is not open up to see the LED string, or you can trace the connector on the driver board to see how it is done.Leave a comment:
Bud M don't laugh at me, but I was hoping to unplug all the LED strings and plug them into a separate power source that would eliminate any feed back circuit from turning the the LED driver chip off.Leave a comment:
It would be nice if these led strings had standards for each size of screen then one could build a test circuit just to plug in and see if the individual strings worked or not, but that would be to easy.Leave a comment:
LED's are wired like christmas-tree lights....
One dead--all out.
You just have to test each one in turn. No schematics, just a meter.....Leave a comment:
That will be correct if all the LED int he string are good, but if one goes open circuit then nothing will happen, but you need to know how many LEDs are in the string to determine what the power supply voltage needs to be, some string you will need more than 100VDC, Vf of each LED is between 3~3.6V.Last edited by budm; 03-27-2015, 12:36 PM.Leave a comment:
his would be a constant current source would be the voltage regulator.
What do you think?Attached FilesLeave a comment:
Yes, something like an adjustable voltage source with constant currentLeave a comment:
OK, are you asking how to test individual LED mounted on the circuit board that form LED string?
You can use 3V battery with 100 Ohms resistor to limit the current for testing individual LED.
Or you already verify that the LED driver circuits are OK but the LED still does not light up?
Test LED string current draw using DCA.
https://www.badcaps.net/forum/showpo...4&postcount=95
Or used indicator:
https://www.badcaps.net/forum/showpo...&postcount=107Last edited by budm; 03-27-2015, 11:55 AM.Leave a comment:
Jump with a low ohm resitor between ps-on and 5v stby, and 5vstby and bl-on (inverter on off)Leave a comment:
please post test methods you use
thanks!Tags: None
