Hello, I have a Phillips 42 inch Lcd tv. As soon as i plug it into an outlet it begins clicking. I assume it is trying to cycle on and off. All 12v pins seem to have the correct voltage. right about 12. The one that I did notice that was wrong is the 3v3 st. As the power supply clicks the voltage fluctuates between 0.90v up to 1.5v. It changes almost every time it cycles (clicks) On the (off) cycle it drops all the way to zero and when its cycles on it never goes above 1.5v. It continues doing this as long as I leave it plugged in. I see no visible bad caps. I believe I have isolated the click to a little black box. I will add pic. Any info on where to check next. Thank you in advance.
Phillips 42pfl3603d/f7 CLicking
Tags: None
Re: Phillips 42pfl3603d/f7 CLicking
picturesAttached Filesif you find these attachements useful please consider making a small donation to the site
Upload good clear pictures of the whole back side of the TV so we can see how many boards are used and how they are connected together, that will be a start.Never stop learning
OK, for the 3.3VSTBY to be fluctuating, I will suspect either the start-up/running cap C104 (47uf 50VDC) is bad, or the caps in that area are bad, or the main board is drawing too much current.
You can try replacing the C104 first.
Pictures provided by ShopJimmy.Attached Filesif you find these attachements useful please consider making a small donation to the site
I dont know if it matters, but when I unplug the white, and black cable from the power supply(going to the main board) it does not make the click any longer. I am going to change these caps now if I have them. Thank youComment
What is printed on the body? and are you sure it is C104?
Please note that the diagram I found may not be 100% match to your board after looking at and compared to the pictures of the board.
I am also trying to find out what C121 is for in your board.
See attached pictures of the suspected bad caps. You can try heating that section with hair dryer to see if the 3.3V will become stable or not.Attached Filesif you find these attachements useful please consider making a small donation to the site
c104 is 4.7 changed it. Same thing. c102 is 47. changed it also. same thing. Im probably crazy but seems like the click is not as loud. Those were the only two I had on hand. I will have to order the others.Comment
What is the Voltage rating of the C104? Also see updated post 8.
Also check the resistance between the chassis and the 3.3V pin, TV is not plugged in of course.Last edited by budm; 03-24-2015, 03:41 PM.Never stop learning
by TrisHClHi,
First post...
I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
I disconnected the main board from the power... -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by jason123Hi folks,
I'm suspecting the actual CCFL or EFL being bad, just not sure how to test, but would like to confirm.
TV clicks upon plugging in AC. When I press the PWR ON button, clicks again.
LED on the Main board comes on green (Assuming some diagnostics), Blue LED on the TCON comes on also when I turn the TV on, but turns off about 30 seconds later.
3V3 ST is on (3.26 V)
Standy 3.3 V (off) when I press power button goes to 0.16 V
12Vssb is 11.75 V (on), 0.18 V (0ff)
+12Voud is 13.8V (on) ~ 0V off
-12Voud is -12.4 V (On) ~0V... -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... - Loading...
