Vizio 47 vo47l power supply DPS-433BP
  • Shane711
    • Dec 2014
    • 493
    Re: Vizio 47 vo47l power supply DPS-433BP
    You mean the 2 Ferrite slug on the power board where I repaired the coils. If they were damaged how would I know? What effect would it have?
      It will not have the same inductance, the problem is that we do not know what the spec of the inductor is, but you may be able to see high frequency AC ripple on the output side of that pi filter if it is not working.
      • Shane711
        • Dec 2014
        • 493
        I have no way to test that. I am guessing I will need an expensive tester like one of those with the screen on them that shows the graph or wave form. Not ready to buy one of them yet.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
