Panasonic tx-p50c2b A board fault
  • Rickig
    • Mar 2015
    • 112
    • England
    Hi guys have a Panasonic board with faulty A board.
    Set flashes 10 times.
    Part number tnph0829 TXN/A1MEUE
    I cannot find a replacement anywhere was hoping someone out there has repaired these before and can point me in the right direction.
    There's a guy on eBay recently advertising a repair service for this board so assume there's a common fault on it.
    Thanks in advance
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tx-p50c2b A board fault
    Thanks in advance
    how did you prove it as A board ?
    • Rickig
      • Mar 2015
      • 112
      • England
      Flash code 10 blinks.
      And unplugging various boards ysus, xsus etc as per another post I found
      Tried new power board.
      • tw2005
        • Oct 2011
        • 6458
        So you tried disconnecting, SC2,SS11,P35, and the 3 white ribbons on the A board and still 10 blink?
        • Rickig
          • Mar 2015
          • 112
          • England
          I can't be 100% it was a while ago, I came across this site thought I'd register and see if you guys can help
          So. If you have some suggestions I will go try them and report back.
          • tw2005
            • Oct 2011
            • 6458
            That is a suggestion. If it 10 blinks doing that then it's A or P but since you've had a shot at P then it would be A. P boards generally are pretty robust.
            Any history on this Tv , symptoms of what happened etc or purchased broken?
            • tw2005
              • Oct 2011
              • 6458
              don't reconnect anything after you undo all those and power cycle it, will have to wait for the voltages to bleed off for a few minutes otherwise things can be damaged including the panel.
              only run it long enough toe get a result.
              • Rickig
                • Mar 2015
                • 112
                • England
                Ok. Will try when I get home. Got it broke of a mate.
                • tw2005
                  • Oct 2011
                  • 6458
                  No worries, I'll be off by then but Tom or someone else may continue when you come back with something.
                  handy to know how it broke sometimes, like someone may say eg.
                  I was watching it and heard a loud pop and the TV shut down and now 10 blinks. Or we had a lightning storm etc
                  If you have not already, download the service manual
                  • tw2005
                    • Oct 2011
                    • 6458
                    there has been a case of 10 blink with the F15v line going open due to blown SMD fuse on the A board , PA5610, 4A 32v.
                    on the underside near a stencil marking Q5471, Q5472
                    • Rickig
                      • Mar 2015
                      • 112
                      • England
                      Thanks I'll look
                      • Rickig
                        • Mar 2015
                        • 112
                        • England
                        Right I found a working A board tried it and same fault. Which prompted me to look elsewhere. Found shorted mosfets on SC board tnpa5063.
                        Anybody had success repairing these? See a repair kit on eBay but it's in the usa. Can't find a uk based service.
                        • Rickig
                          • Mar 2015
                          • 112
                          • England
                          Fixed...
                          10 flash
                          Changed sc board. Tv now fixed
                          • tw2005
                            • Oct 2011
                            • 6458
                            Fixed...
                            10 flash
                            Good to hear.
                            I can't help but wonder if you ever followed through with what I suggested early on?
                            If that was done , we should have been able to determine if 10 blink was A or SC and that was the intent and purpose of that step.
                            Anyway, pretty sure those A boards are hard to get and they do fail so a handy spare or you should be able to resell it.
                            Plus you now have a working TV to test it to be sure it's good
                            • Rictech
                              Panasonic SA-MAX770PU SMPSU board fault....
                              by Rictech
                              Hello everyone. 😀
                              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                              There are no devices that have exploded or otherwise show signs...
                              08-26-2024, 01:05 AM
                              After all of...
                              07-13-2024, 08:14 PM
                            • spleenharvester
                              Tower T548006 battery, fault on BMS board
                              by spleenharvester
                              I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
                              10-04-2025, 06:33 AM
                            • tony359
                              2007 Macbook logic board fault
                              by tony359
                              Good day all,
                              I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                              Once the fan was swapped, I installed an OS and it worked fine.
                              The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                              Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                              If I see that right, I have missed VCORE on L7100 (page 59)....
                              01-23-2025, 06:59 AM
                            • dajoker
                              Panasonic th-p50s10d - blinky red, SC board go boom
                              by dajoker
                              My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                              I chased my way through the PSU, and a board, with no results.
                              Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                              I only have the right half of the picture.
                              Left half is completely blank.
                              now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                              all the other voltage rails...
                              09-24-2024, 04:39 AM
