bush DLED32165HD startup issue
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok guys another crap tv with vestel boards, this Bush DLED32165HD tv trys to start up. i get 5 steady blinks then it misses a blink and gives me another 5, im guessing this is an error code does anyone know ? is there any firmware for this tv i could try ?
    Re: bush DLED32165HD startup issue
    Have you checked if the PSU works first?
    Vestel sets don't use error codes (afaik)
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      i will test PSU and check voltages and update post.
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        Tom how would i go about checking this PSU as the pins overlap each other ?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          Carefully is how... :p
          You could use test hooks if you have some really small ones, or take the boards out of the set and probe the back side.
          Another option would be to solder wires on the underside and connect to those.
          -David VanHorn
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            ok unscrewed both power and main as there connected together, flipped upside down, plugged tv in and tried to switch on but got 0v reading from all pins with multimeter set to 20v am i doing something wrong ?
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              Hard to say. Did you disconnect anything?
              Also, make sure you don't let the boards short out on anything.
              -David VanHorn
                • 31094
                maybe the frame is used as common ground - i hate that!
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  i just too flipped them upside down everything connected, tv light still flashes as if trying to switch on so i know there is power there just dont show anything on the multimeter.
                    What are you using for the GND ref for your meter? The Secondary side circuit GND is connected to the chassis when the boards are mounted to the Chassis.
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      for the GND i was using a hole on the chassis on the back of the screen, is that suitable ?
                        If the boards are not mounted to the metal chassis then the circuit GND is not connected to the chassis, if you look at the circuit board mounting holes you should see exposed copper pads which will have trace going to the negative legs of the power supply output filter caps, you can then use those pads for your meter GND ref. point.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4981
                          • New Zealand
                          Not if the boards aren't connected to it. Then it isn't ground, it's just a piece of metal. You need to use the actual ground connection on the board.
                          -David VanHorn
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            What if i use speaker wire and use it to ground the PSU to the chassis of the tv ?
                              You could do that but why wouldn't you just use the ground on the board. You are just overcomplicating it.
                              You must use the secondary side ground, i.e. nothing on primary/live/danger side....
                              • shahnld
                                Lenovo legion 5 pro startup issue
                                by shahnld
                                Good day Experts
                                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                08-24-2025, 12:31 PM
                              • db80
                                Lenovo Ideapad 5 15ARE05 startup issue
                                by db80
                                Hello friends,
                                I've been racking my brain over the past few months on the following issue:
                                I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                                If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                                Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                                I tried all the common alleged „fixes“...
                                07-06-2024, 05:58 PM
                              • ResetReality
                                Toshiba/Vestel 58UL2B63DB Wifi Issue???
                                by ResetReality
                                Hello fellow tech heads.
                                Had this tv come in...issue stated reboots on wifi.
                                Indeed it does. However, with wifi off or using cat 5 cable no reboot issues.
                                So far ive changed mainboard and wifi module...also reset tv back to factory via service menu (4725)
                                Still same issue... i do have a psu to swap but cant see it being that really as works flawless if wifi is disabled
                                I thought fireware? But why only on wifi?
                                Is it an issue with the memory cache filling up and having to reboot for more ram??
                                At a total...
                                07-04-2024, 12:28 PM
                              • FlailingEngineer
                                Help with Bush Tv (Vestel 17mb95m Mainboard)
                                by FlailingEngineer
                                Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                05-31-2023, 06:52 AM
