Zemtronix Repair Kits
  • Ltank
    • Jun 2013
    • 776
    Does anyone know about the Zemtronix Circuit Board repair kit sold on Ebay?
    The kits do not specify what problem it addresses. Are they common parts that fail regularly? Kits don't list parts included. I checked voltage regulators and capacitors.
    Vizio E472VLE MB 3647-0602-0150 Repair kit is -171-2272-4314
    Thanks Guys
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Re: Zemtronix Repair Kits
    I ordered a kit for a Vizio M420SV with 0171-2272-3714 board. They stated the three components that come in kit in order of likely fault,#1 voltage regulator, #2 EEPROM, #3 Main cpu.
    Haven't received it yet. I will update thread will results.
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Got the kit in and all it contained was two am117 voltage regulators and two 5amp/125v smd fuses. I read his email incorrectly. This kit was for only one fault that it could be. Would like to try eeprom, but there are none available for this unit.
      Check voltages on U3 and U9 and the two white fuses by connector on main board to make sure that is your problem.
      My TV on power up, vizio logo on bezel lights up, goes amber, lights up again with backlights, then goes amber again. Main board is $118 and I am too cheap. Good Luck.
      • whiz62
        whiz62
        • Dec 2013
        • 242
        • usa
        Just noticed you have a different model so u3and u9 might not be correct on your board. Sorry..
        • Nick's Tvs
          • Jan 2014
          • 621
          In case anyone is ever wondering about Zemtronix for future reference, DO NOT USE THEM. Be aware of any company that sells kits but does not offer repair services.
          I have in the past purchased their kits, and while the parts they sell are good working parts they rarely address the most common issues that your board is actually going to be having.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • yuii
            ThinkPad W530 - faulty CPU regulators?
            by yuii
            Hello
            I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
            Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
            The latter is completely dead and has the same 2-second power blink, nevermind...
            11-01-2023, 02:59 AM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
