Sharp lc32dh500e
  • gazza544
    • Nov 2013
    • 19
    Sharp lc32dh500e
    hi all, having trouble with the Tv, it has no tcon because it's in the main board, getting a backlight on but no video, changed the main board but still have no video, anybody have any ideas? Thank you in advance.
    Re: Sharp lc32dh500e
    I had a look a pic of a main board - not certain it was right, but it did not look like the T-con was on there. Are you sure it's built in to the main board? An actual picture of your board would really help.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      http://www.tv.quuq.org/forum/index.p...e;topic=6174.0
      This may help you.
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
