panel swap question sharp to sony
  • freakaftr8
    • Oct 2012
    • 3743
    so I picked up this sharp LC-60LE632U that has a cracked screen. in my parts room I have a good screen from a Sony KDL-60EX700 that uses a sharp panel. Both TVs are 120hz 1080p and judging by the tcon photos both the output ribbon connectors are the same size and dimension. Of course the Sony uses an integrated Motionflow processor in their Tcon and Sharp does not. however my plan is to take they Sony panel which is a sharp manufactured panel and connect it to the sharp t-con board. I've had luck swapping panels with their t-con board into other TVs that use the same model or I should say make panel. Considering that both panels are sharp and they both have the same number of pin outs on each left and right ribbon I wonder what the chances of success are? anyone care to shed any light?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: panel swap question sharp to sony
    Does the panel even though made by sharp have some kind of proprietary Sony added motionflow Mumbo-Jumbo? I'm about to find out the old fashioned way soon.
      Are the panel numbers the same or very similar? You gotta be careful you could fry the replacement panel so I would take care.
      • freakaftr8
        • Oct 2012
        • 3743
        No the panel numbers were way off. She tried to work but it turns out that the Sony screen is also cracked it was really hard to see but there's a small crack right in the center of the screen. Oh well chalk this one up for more parts.
        one lesson learned if a Sharp LCD panel is cracked bad enough it will give the 2 - 5 blink.
          Yeah bad crack will mean shorted panel which will trip a fault code.
          • advant
            by advant
            02-03-2020, 12:25 AM
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • rimwall
            Sony KD-65x8500b - bad Tcon or panel?
            by rimwall
            Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
            a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
            b) the Tcon board is malfunctioning,...
            10-24-2023, 07:58 PM
          • netgearnetgear
            TCL 43S423 TCON OR PANEL FAULTY???
            by netgearnetgear
            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
            08-20-2025, 06:04 PM
