LG 50PK590 reversed picture
  • sintv
    • Feb 2015
    • 37
    • scotland
    Iv a LG 50pk590 that comes on with the menu and picture as in a mirror image with flashing lines going across the screen. Iv seen this once on a LCD and it was a screen fault. Tried factory reset. With the LG 'no signal' bouncing about the screen, that's not reversed strangely enough. Thanks
    found this online http://www.youtube.com/watch?v=g7-YrQVXAUM
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 50PK590 reversed picture
    Control board ? Activate the built in test patterns and see if the problem is the same.
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • arbitarytwist
      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
      by arbitarytwist
      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
      03-01-2025, 01:16 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • nasdaa
      Packard Bell Kayfo, no picture on screen.
      by nasdaa
      Hello, I need your help for a failure on a laptop:
      It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
      I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
      06-20-2023, 01:27 AM
