Hi, First timer here wondering if there is another option out there other than ModusLink PTS(searches on forum got me that far - thanks!) to get my TXNSC1DRUU , TNPA4782AF board repaired. Not many of these around to buy anymore and I just don't have the solder skills to do the repair myself. Maybe there is still some used out there that could be operational? Thanks in advance for any replies..
Looking for Panasonic SC board
Re: Looking for Panasonic SC board
even if there was one , i doubt it would be for sale any cheapaer than the repair services
I would not recommend self repair either as the odds of failure are high for the beginner and even some experienced here have failed
$120 http://www.ebay.com/itm/REPAIR-SERVI...item4ad7547430
He's actually posted here, came here looking for help repairing another Sc, looks like he'd managed to work it out and make income from it.
Has not posted since.Last edited by tw2005; 03-07-2015, 07:27 PM. -
I can vouch for moduslink work, I have used them a few time and it's been nothing be stellar. Sure you pay a little more then other repair places but these guys specialize in these sort of repairs and they to a knock out job.Comment
Its fairly simple component replacement, buy the repair kit off Ebay and do it yourself. Ive done 3 so far with good results.Comment
if you're proficient at it, can you do a guide up on the 3 boards you had successLast edited by tw2005; 03-08-2015, 01:53 AM.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
