Philips 46PFL8605H LCD shuts off after 5-10 secs
  • Nicholas
    • Dec 2014
    • 60
    • Kingdom of Denmark
    Hi guys!
    Well, this Philips 46PFL8605H LCD TV shuts down 5-10 seconds
    after it has been turned on.
    What could be the fault? PSU or maybe main?
    Thanks!
  • Nicholas
    • Dec 2014
    • 60
    Re: Philips 46PFL8605H LCD shuts off after 5-10 secs
    Slight bump
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      You have to give us more information than that. Does the TV go back into STBY? Is there still sound and just the backlight that turns off... etc... Pictures would be great. Other than that, I don't think you will get too much response.
      • Shobos
        Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
        by Shobos
        Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
        So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
        NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
        Any help is welcome. Thanks !
        07-29-2025, 03:53 PM
      • alltvrepairs
        Philips 50PUS8555/12 Power supply fault
        by alltvrepairs
        715ga018-p01-006-003s
        Am trying to find a pdf .
        i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
        tried with meter most components like resistors diodes etc.
        in secondary there are no shorts either.
        This was struck by a lightning and could see a burn under the air gap capacitor.
        Attaching the board.
        Any clues welcome.
        Tks...
        08-30-2025, 08:42 AM
      • limxrich
        ASUS X560UD - shuts off after 3-5 secs whenever RAM is present
        by limxrich
        Working on an X560UD. Unit turns off whenever RAM is present. Tried multiple known good memory sticks, but still, unit shuts off after 3-5 secs. When RAM is removed, unit stays on, but of course, do not POST.
        Happens on any o the two slots, 1.2V present.
        Any clues?
        08-10-2022, 07:17 PM
      • Biruslapio
        Philips 50 Inch 6654 4k display fault
        by Biruslapio
        Hi, this TV is from the PUG series, had no image, upon using tape to cover the pins on the right side(from the back), it displays only vertical bands that fade away slowly, classic problem with the horizontal part.
        There is no short I could find on the panel, when disconnecting any major voltage such as VGH, the T-Con stops pulling down all voltages and I can measure what they should be.
        I tried to use an external power supply in place of VGH, as soon as I turned on the tv displayed proper image and then instantly started to fade, T-Con shut down all voltages, it is sensing...
        04-10-2024, 11:13 PM
      • vernond
        Philips 42PFL3609S/98 Shuts down after sometime
        by vernond
        Hi.
        I have a Philips 42PFL3609S/98 TV that shuts down after some time. If the TV is not power overnight and is powered on in the morning then it will last longer sometimes up to 2 hours. After the first shutdown, it will be more difficult to switch it on again. It would be easier to restore power if I remove the AC cord and plug it back again.
        Replacing capacitors C805 and C804 didn't solve the problem but made the running time last slightly longer. The old capacitors were giving me a reading of 920 uf. C840 and C840A are giving out a reading of 72uf and were not replaced....
        08-19-2021, 08:02 AM
