TC-P50C2 Panasonic color problem, HELP!!
  • peekywhop2
    • Mar 2015
    • 5
    A friend of mine has the TC-P50C2 and the color is acting all funny now. Its like a pink and green color and I will attach a photo so u can see my problem. Any help would be greatly appreciated!
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P50C2 Panasonic color problem, HELP!!
    A tough one. I'd be inclined to get it into service mode and access aging and run through the test patterns. these do tend to blow SS boards, and I'm kinda thinking it's a sustain board not right but still very undecided
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Worth checking the LVDS cable at both ends--Sometimes the sockets/plugs on it develop poor connections....
      I had a 50PZ80 that had a pink cast to the picture--That was it.....
      TELEFIX
      • peekywhop2
        • Mar 2015
        • 5
        How do I get it into service mode do you know? And from the service mode will it tell you if there is a board is failing?
        How do I go about checking if this part is bad?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Well--You treat each end to some switch-cleaner and re-fit!
          TELEFIX
          • Ltank
            • Jun 2013
            • 776
            I suspect the Zsus board because of the pink tint being early stage of Mal Discharge
            2nd possibility is the control board
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • hugocarmo
              Panasonic TX-24A1UN CRT Sound and Input problem.
              by hugocarmo
              Hi.
              I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
              It is imaculate inside, almost no dust or debris inside.
              The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
              So I started to look for a service manual, I found one, and started from the beginning.
              Most of the times the caps are the problem so I orderer all the caps for all boards,...
              04-26-2025, 07:45 PM
            • renech
              panasonic TH-42PC77U plasma television half screen problem
              by renech
              hello,
              I hope someone on this forum can assist me.
              I have a panasonic TH-42PC77U plasma television.
              the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
              i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
              I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
              I have read some posts that suggest the problem is related to the boards on the left...
              12-12-2022, 06:53 PM
            • Vebririon
              panasonic TX-P50V10E 6 blink led problem
              by Vebririon
              I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
              Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
              I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
              05-17-2025, 10:16 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
