Olevia 323-S11 No Standby
  • SolderMaster
    • Dec 2013
    • 53
    Hi folks,
    I have an Olevia 323-S11 that has no standby light. The fuse on the PS is good.
    Voltage across C1 = 170VDC
    I have already replaced bulging caps CS21 CS22 CS28 CS23 CS20 CS19
    122VAC across pins 2 and 3 of bridge rectifier.
    Possible problem area is the 4 pin ICs. IC5 in particular. Pins 3 and 4 read 0, Pins 1 and 2 read approx 58VDC. There isn't a service manual that I have found for this model.
    I was reading through the other 323-S11 thread and thought I should create my own thread.
    Re: Olevia 323-S11 No Standby
    Pictures of the board please.
    "Possible problem area is the 4 pin ICs. IC5 in particular. Pins 3 and 4 read 0, Pins 1 and 2 read approx 58VDC. " That sounds like OPTO IC, what did you use for you meter GND when making Voltage mesurement in the Primary side and in the Secondary side of the this IC?
    Did you replace the start up cap in the primary side for the STBY power supply section?
    • SolderMaster
      • Dec 2013
      • 53
      I used the ground of C1 for the primary side and for the secondary side I used the screw ground by LS3.
      I don't know which cap is the start up cap. So, no.
      I'm using a Fluke 77.
      • SolderMaster
        • Dec 2013
        • 53
        Correction,
        On the primary side I used the negative leg of C1
        On the secondary side I used the negative leg of ZDS1. (That's why those voltages were jacked) On the IC5, I get 0 on pins 1 and 2. On IC4 and IC6 pin 1 = 5.15VDC, pin 2 = 4.44VDC, On IC7 I get 4.3VDC on pin 1 and 3.3VDC on pin 2.
        Which cap is the startup cap for the standby?
          C8, c31, 32, 33, 34.
          IC2 is the STBY SMPS IC, get the P/N.
          IC3 is the PFC Voltage booster IC, get the P/N.
          IC1 is the 12V/24V SMPS IC, get the P/N.
          The primary filter cap looks like it has slightly domed top.
          • SolderMaster
            • Dec 2013
            • 53
            OK, I replaced C8, C31, 32, 33, and 34.
            Still no standby light.
            BTW, thank you for your help. Am I measuring the ground correctly for the secondary side?
            • CapLeaker
              Leaking Member
              • 8182
              you can buy that thing for $26 incl. shipping.
              Actually did you verify the STBY voltage with your meter, or did you just plug the main board in and watch the LED?
              • SolderMaster
                • Dec 2013
                • 53
                Just watched for the LED to come on. I'll check for standby voltage now...if I can find which pin it should be on.
                It's just an Easter egg hunt without knowing what the pins are. UGH.
                Where can I buy one? Shop Jimmy has one for $51...
                  https://www.badcaps.net/forum/attach...4&d=1425241457
                  Cap CS28 is the output filter cap for the standby Power supply, the positive legs of that cap looks to be connected to connector CNS1 PIN 2~4 (RED WIRES).
                  • SolderMaster
                    • Dec 2013
                    • 53
                    The voltage on those pins is fluctuating between 1.4 and 2.1VDC. I used the heatsink of CRS3 as a ground....also used the last pin on the CNS1 connector...assuming that is a valid ground.
                    • SolderMaster
                      • Dec 2013
                      • 53
                      I don't see IC1, 2 or 3. Only 4-7. Part number for those is M TD PC123. These are the ones with pins 1 and 2 on the secondary side and pins 3 and 4 on the primary side.
                        Look again at your picture:
                          You are better off spending $26.
                          • SolderMaster
                            • Dec 2013
                            • 53
                            OMG...DUH.
                            IC1 = 900T603
                            IC2 = EA1532A SR0E612 Hn66041
                            IC3 = 28051 59M CXFE
                            C1 does look a little domed but it is reading 170VDC.
                            • SolderMaster
                              • Dec 2013
                              • 53
                              Ok, where is this board for 26?
                              • CapLeaker
                                Leaking Member
                                • 8182
                                Aliexpress
                                • SolderMaster
                                  • Dec 2013
                                  • 53
                                  Ordered...thanks guys!
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • corrize
                                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                                    by corrize
                                    Hello, I search this connector (oxydated).
                                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                    Do you know how to find this connector please ? What is the exact name for find it ?
                                    08-06-2024, 05:25 PM
                                  • psssst
                                    Yamaha TSX 120 Standby Problem
                                    by psssst
                                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                    03-01-2024, 07:25 AM
                                  • reessi
                                    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                    by reessi
                                    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                    Years ago it had some bulging caps...
                                    04-26-2021, 11:42 AM
                                  • ChristianBr01
                                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                    by ChristianBr01
                                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                    04-23-2025, 01:48 AM
