LG 37LC2D - Backlight, no pic or sound
  • igotquestions
    • Feb 2015
    • 15
    I'm completely new to the forums so please correct me if I do something wrong or post in the wrong location.
    So here's the situation:
    A week ago I found an LG 37LC2D-UD tv in the hallway next to the stairs, not having one I decided to take it thinking I might get lucky. After searching up the serial number I came across this forums and read up a lot of what other people experienced with the tv.
    At the time of posting this I'm currently visiting home so I can't add pictures until sunday evening. This is the first time I've ever done any electronic stuff so I'm kind of posting to see what I can do here.
    After stripping off the back and looking at the PSU, I noticed one bulging cap at C200, the pins are very close together and I've never soldered anything before so I'm kind of nervous about trying to fix it. Nonetheless I'm currently in financial distress so I haven't gotten the chance to order the repair parts. I was looking at this http://www.amazon.com/37LC2D-UD-CAPA.../dp/B00M1AJCRY in order to purchase the tools and the cap I would need to replace.
    I do not have a multimeter to test the other caps, nor do I know how to even test them if I did have one.
    Basically what I'm asking is, is it worth trying to fix this tv? I don't have one currently and I room in a 4 bedroom apartment so something in the living room would be nice.
    And since I'm not next to the PSU i think the cap was a 6V that was bulging. I apologize and will edit my post accordingly once I get back to my apartment.
    Thanks for any help you guys can give me. Good luck on your own endeavors!
  • igotquestions
    • Feb 2015
    • 15
    Re: LG 37LC2D - Backlight, no pic or sound
    Anyone able to offer any insight to the situation? I'd like to come up on a $400 tv for the price of that amazon repair kit haha.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      I repaired one of these not long a go i managed to get a replacement power supply for about £15.00 so i opted for that route the kit you have listed does not seem too bad i wonder if you can email the seller and ask them what capacitor make/series is used i tend to use panasonic myself when i buy capacitors.
      • igotquestions
        • Feb 2015
        • 15
        So I received the package as of 30 minutes ago. I replaced the obvious bad cap (bulging) and then i proceeded to screw on the psu and test it. Upon turning it on the first time the tv worked. It said HDMI in the corner whereas before this point it didn't say anything. I was using the buttons on the side and couldn't get the volume or anything to pop up on the screen. So I turned it off and tried to the use the remote. Upon turning it on with the remote the light blinked 15 times and now I'm at the same point again where nothing is working.
        Now, what would you veterans do in this position as this is the first experienced I've had with anything of this sort of tasks.
        Is there a location someone could direct me to maybe look at replacement PSUs for the TV? As I'm sure that buying a replacement PSU will be cheaper than buying a new tv.
        Thanks for the help.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Did you replace all the capacitors in the kit? or just one just because there not buldged dosnt mean there not bad.
          • igotquestions
            • Feb 2015
            • 15
            I only replaced the one that was bulging. Should I replace all the capacitors with the new ones i've received? This is the first experience I've had soldering anything so I'm slightly worried I might mess something up. Is it worth doing before I try looking at a replacement PSU?
            Thanks again for the quick response I do really appreciate it. A tv would be much better than staring at my laptop trying to watch a tv show or movie.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              if you take your time i guess its worth trying just make sure you replace the capacitors with the same uf and voltage that you remove and make sure you get the polarity right one side has a line which is negitive (theres also a mark usually on the circuit board under the capacitor too) just check as you remove them once youve done a couple it will get easier. look on you tube too theres some good videos on soldering capactors etc.
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • triplefour
                TCL 75S421 has sound but no backlight not even a flash
                by triplefour
                TCL 75S421
                PSU BOARD: 40-L402H8-PWD1CG
                it shows not even a flash of backlight when powering up.
                but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                with mb connected, PSON...
                11-17-2023, 09:54 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
