Sanyo DP47460 On Then Back Off
  • johnboy1313
    • Nov 2012
    • 1959
    It doesn't seem to be IC1670.
    My buddy brought this to me. Like many, many other Sanyos, this one turns on for a second, shows the Sanyo logo, and then turns off. I removed IC1670 from the board and still have the same problem. I've tried jumping the PSU on. With the main disconnected, I get no backlights when jumpered from 5V to PS_ON. I'm not sure what pin to jump to get backlights. With a jumper to PS_ON, the PSU just clicks on, then off over and over with no backlights.
    If IC1670 was bad, would removing it entirely let the set turn on with no volume? If IC001 was bad, wouldn't removing IC1670 from the board isolate IC001? Thanks
  • CapLeaker
    Leaking Member
    • 8120
    Re: Sanyo DP47460 On Then Back Off
    Disconnect everything from the PSU and force it on. See what you get on the output rails.
    • johnboy1313
      • Nov 2012
      • 1959
      I tried that. It just clicks on and off over and over with no backlights. I'm not even sure I'm doing it right. I have a resistor between PS_ON and 5V. I don't see BL_ON on this PSU.
      • CapLeaker
        Leaking Member
        • 8120
        I wouldn't frig with the main board until I can force on the power supply and it stays on. Do any of the outputs come up for a split second, or are they just 0V? Did you check IC602, the fets and diodes?
        • johnboy1313
          • Nov 2012
          • 1959
          With the main connected, all voltages other than 5V come up and then die. With the main disconnected, I get all voltages on the connector J617 for a second and nothing on the connector to the inverter.
          • CapLeaker
            Leaking Member
            • 8120
            Can we see a pic of the back of the TV with all board connected?
            • johnboy1313
              • Nov 2012
              • 1959
              Here you go.
              • CapLeaker
                Leaking Member
                • 8120
                I guess it is one of these weird made TVs where is no BLon on the PSU itself. Here it comes from the main board. So... by right's if you force the PSU on, the 24V rail should be up as well, but the BL itself should stay off. So there must be another switch on the inverter that gets the BLon command from the main board. Uff. That is complicated. I am not sure yet, what that Line OFF pin does.
                With the main board connected, you said all the voltages but not the 5V rail came up. There is a power failure circuit. When the unit sees something not fit, it will shut down. I would poke around there and see if that is true.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  No, the 5V is the standby. Everything comes up and then drops out except the 5V. It doesn't drop out. Sorry if I wasn't clear.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Have you checked all the diodes on the output, primary fets, and the pfc are all running ?
                    Also could you take pictures of the Ic that you replaced ?
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      No, I haven't checked any diodes or FETs yet. PFC seems to be working. Main cap jumps from 170 to 390 while it's on. I didn't replace the IC, I removed it and reinstalled it once I found that the fault continued.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Start checking them and replace that Ic...
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I don't know if the IC is bad. The power supply clicks on and off with the main disconnected. The IC is on the Main.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Could you take photos please ?
                            • CapLeaker
                              Leaking Member
                              • 8120
                              So PFC is o.k. then
                                The BL-ON cable is connected directly between the main board and the inverter board.
                                The connector K8L pin 3 is the BL-ON, service manual page 26.
                                If you remove K8L, the backlights should then come on., it uses the same setup as the 26". This 26" has the same problem, no backlghts, the main board was bad.
                                http://s807.photobucket.com/user/bud...ml?sort=3&o=21
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Cool. Thanks for that info bud. Ill be digging back into it later this afternoon. Reeseyburger123, I'll get pics then too. Thank you.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    So now the backlights aren't coming up at all anymore and the PFC is not working anymore. The relay clicks just like it did before. Then it clicks off, just like it did before but no PFC or backlights.
                                    Here's that pic of IC1670. The 1uf 50v cap at C1676 came off when I used hot air on the chip. I didn't see it come off. I replaced it with an extra I had from the last Panasonic I fixed.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      I apparently broke the relay being heavy handed. I replaced it and now I have PFC and backlights for a second again only with the main connected. When I disconnect K8L, I get no backlights at any point, both with the main connected or with the main disconnected and a jumper from 5V to PS_ON.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        So non of the voltages still dont come up, just check the soldering on that chip no offence but it looks a little rough.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
                                          HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
