Sanyo DP47460 On Then Back Off
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sanyo DP47460 On Then Back Off
    Originally posted by ReeceyBurger123
    So non of the voltages still dont come up, just check the soldering on that chip no offence but it looks a little rough.
    The voltages do come up, just like they always have. Then they drop out, just like they always have. You really think the soldering looks rough? The extra flux looks bad, but the soldering itself looks fine to me. Out of curiosity, why are you so focused on that chip? The power supply cuts out regardless if the main is connected or not. I'm not saying the chip is good, just that there is more going on than just that chip.
    • johnboy1313
      • Nov 2012
      • 1959
      So PFC is o.k. then
      I apparently haven't done my homework like I say I have. I have a few TVs I'm working on at the same time. As of right now, the backlights come on for a second, but the main cap never goes above 168V. Either my meter isn't fast enough to catch it (it doesn't even flutter, if anything, it drops a volt or two before the lights cut off) or the PFC isn't working. I apologize for saying otherwise. I must have gotten the two power supplies mixed up. It's surprising to me that the backlights would come on at all if the PFC wasn't working.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        You said it was bad and had to replace it, have you checked for sorts all over the psu board ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          So your pfc isnt running, have you checked all the controllers and diodes for the pfc circuit, also check the bridge rectifyer.
          • johnboy1313
            • Nov 2012
            • 1959
            I never said that. I said I pulled it off and the problem persisted, so I put it back on. Yes, I have tested for shorts. I haven't found any yet.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8326
              Maybe you damaged it While pulling it off?
              • johnboy1313
                • Nov 2012
                • 1959
                I didn't really pull it off. I used hot air. It kinda just slid off. It may in fact be damaged, but for right now I'm sure the power supply isn't working. Shopjimmy sells a kit for this exact condition for $22. It's not my money to spend so I gotta talk to my buddy about it. I'm pretty sure the FETs and diodes are good in the PFC but I'm not sure about IC602 on the bottom. It's a 16 leg chip. There's no markings on it that I can see. If I knew what that chip was, I'd probably just source it by itself. Once I'm sure the PSU is working, I'll look at that IC1670 if the set doesn't come on.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8326
                  Post a high res pick of it, maybe you are lucky enouh and someone IDs it for you.
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 08:10 PM
                    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
