LG 50PS3000 No Voltage
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Got this 50 inch LG plasma TV in, When power lead is connected the tv goes into standby with red LED, When i turn the set on the LED changes to blue and it clicks but i get no display or light from the screen, Tested with a multi meter and im getting 0 volts on both Va and Vs.... Is this a common fault with this tv?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 50PS3000 No Voltage
    Common fault on All Plasma sets!
    Check for shorts on Vs lines to both Y-SUS and X-SUS.
    TELEFIX
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      Here's a few pics of the power board, I'm not really sure where to check first, Could you suggest where to start..
      https://lh5.googleusercontent.com/-b...225_113946.jpg
      https://lh6.googleusercontent.com/-w...225_113936.jpg
      https://lh4.googleusercontent.com/-5...225_113906.jpg
        Have you tried isolating the Y-sus and Z-sus? Shorted Z-sus is very common on these, usually the TV will buzz loudly when you try to turn it on followed by relays will clicking off.
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          Yeah Tom, I already tried disconnecting all boards from power board one at a time and always got the same thing accept for when I removed the main board I got nothing then.
          • MagicSmoke
            • Feb 2011
            • 275
            If it still blows fuse when Y and Z boards are disconnected then fault is on PSU. It can be a bad diode, a shorted Fet, or a number of other things.
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              Its not blowing fuses, just no va or vs voltage when set is on, led change from red to blue as if tv is on,
              • MagicSmoke
                • Feb 2011
                • 275
                Some PSU's will shut down VS and VA if there is no load on it. Are any other voltages different or present when tv is on compared to off?
                You should be able to jumper 5v Stby to PS-on with a resistor to force PSU on to check other voltage readings. There may also be a VS on pin or the like to activate the VS and VA volts.
                Cannot see pin legend on bottom right connector in your pics. Too fuzzy.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                  ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                  3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                  Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                  core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                  configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                  serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                  Based on Intersil's Robust Ripple Regulator...
                  11-05-2024, 03:24 PM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
