Samsung UE46B7020WW Screen Fault
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, Just got this TV in yeserday and it has very faint lines all across the screen, Does this look like a bad pannel or bad tab bonds? Or could it be something else?
    http://tinypic.com/r/2lbe5aq/8
  • sordids999
    • May 2013
    • 2155
    Re: Samsung UE46B7020WW Screen Fault
    slim chance but have u tried pressing gently on the BGA on the main board using the other end of a insulated screw driving or even try heating up the main board with a hair dryer
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      Haven't tried that yet, Ill try now and post back with results, Thanks
      • Dang
        • Aug 2013
        • 440
        I had this exact same Tv with your issue except I also had the inclusion of bright vertical coloured lines, if you search Google for the T-con board number you will find all your answers, definitely a bad screen.
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          So it cant be fixed?
            Can you upload a photo here? Tinypic not working for me.
            • sordids999
              • May 2013
              • 2155
              i dont think he can tom due to it being a video he posted on Tinypic
              • sordids999
                • May 2013
                • 2155
                This might work if not can you delete it converted to gif
                  Can't see anything in that, don't worry about it, I'll have a look later if I get time.
                  • Easky15
                    • Sep 2013
                    • 285
                    • Ireland
                    Here is a pic i took though the fault is easier to see on the video,
                    https://lh4.googleusercontent.com/-H...222_234420.jpg
                    • Easky15
                      • Sep 2013
                      • 285
                      • Ireland
                      The image is slightly clouded with faint lines running through the whole screen
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
                      • JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                        by JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                        Please help. Thanks in advance!
                        08-12-2025, 11:45 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • arbitarytwist
                        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                        by arbitarytwist
                        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                        03-01-2025, 01:16 PM
