Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
  • slybunda
    replied
    Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
    Originally posted by lotas
    Sck-10(2) The last digit indicates amperes.
    Ahh cool, what sort of wattage should it be?
  • lotas
    replied
  • slybunda
    replied
    Found some options but not sure
    https://uk.rs-online.com/web/p/therm...s/0467620?gb=s
    That one above seems to be rated at 1.8w so may be an issue
    This one below is 3w and i think 4a
    https://uk.rs-online.com/web/p/therm...s/7691861?gb=s
    Again not sure if they will work for me but i can get these tomorrow morning since the shop is close to me
  • slybunda
    replied
    SCK-102 - NTC thermistor 10 Ом, 2 А, 20%
    Odd the info i got from here: https://www.lcsc.com/mobile/product-...Y_C211173.html
    Says its 10 ohm 3 amp 2.4w?
  • lotas
    replied
  • slybunda
    replied
    also done multimeter test on the bridge rectifiers part number D25XB80, both tested fine no shorts.
  • slybunda
    replied
    took the relay off and had a look inside, all seems good, was also able to get a look at the blown thermistor, looks like its a SCK 102
    pics attached
  • slybunda
    replied
    backside of the working thermistor has a line going through it, not sure if thats normal or not. pic attached
  • slybunda
    replied
    just to add, iv checked the mosfets with multimeter and not seeing any shorts , the 2 blown thermistors have resistance values of 38.5ohm and 226kohm. the not blown one on the board has a reading of 14.2ohm.
    issue is that the tv once turned on wont turn off. now i dont know if thermistors can cause that sort of issue.
    also not sure what would have caused them to blow in the first place? power spike from the mains or something else? odd that when turned on the tv stays on and works fine for hours.
  • slybunda
    replied
    added some extra pics of the board incase anyone is interested or has similar issues and would benefit from them.
  • slybunda
    replied
    looks like i may have found the problem: pics attached
    looks like 2 green things i think they were thermistors are popped. not sure what type they were but found another green one next to another one of those black boxes which might be a relay of sorts.
    what to do? not sure what the original ones were in size or type since they blown up and cant see any marking on them now.
    guess its good news that there is something visible to this. also that would explain the loud popping noise i get when turning tv on sometimes.
  • slybunda
    replied
    tv was doing the same thing today. powers on and stays on and works fine but when power button pressed on remote tv goes off but then comes back on and keeps cycling on and off until i press the power button on the remote while its got the red light on and off and then it powers on and stays on.
    have taken it off the wall now since i had some help from the wife. deffo a 2 man job to take it off the wall.
    will take the back cover off tomorrow and have a look inside.
    some pics attached
  • lotas
    replied
    So maybe your TV button itself is “leaking”, has oxidation inside, which leads to false activation of switching on and off.
  • slybunda
    replied
    its a toshiba 75u6763db.
    when i press power button the screen goes off and i hide the remote behind me but tv still comes back on by itself and turns off and on again and again until i catch it when the red light is on and hit the power button on the remote then it turns on and stays on.
    however last night it seems to have stayed off but iv not tried using it today. will try it and post back.
  • vinceroger69
    replied
    Originally posted by slybunda
    i got this problem with my toshiba tv which is a vestel board inside. tv turns on and stays on but pressing power button on remote it goes to standby mode but after a couple of seconds it powers back on and then keeps turning off and on unless i press the power button on the remote when its in a power off cycle with red led light it will then stay on.
    when on its no problem works fine but cant have it on all the time. not sure where to begin with this its a 75 incher so not easy to move around or take off the wall.
    What is the full make and model number of the tv maybe its the ir sensor board at fault
  • slybunda
    replied
    i suspect this may be the board im dealing with:
  • slybunda
    replied
  • Silver1983
    replied
    HI TEAM
    I need help , i have a HYUNDAI SMART TV NODEL/ 40HYN114DLED-SMART with VESTEL shassis17MB95M and ic epprom MX25L1606E . When i take it and put power stby red led blinking all the time . i flash the epprom with a bios who buy from biosfix but the tv do the same. At first look i see that remote control it works becouse when i put the power buton the tv goes to stunby and red led stop blinking and stay on with red, if give again order from r/c start blinking again. after the prosses write bios the remote control now is not respond . one friend give me the loader pkg for update from usb.now i cant do it becouse if give order from r/c ok it didnt responde tv with r/c .
    What must do know and where can find the corect bios for respond again r/c with tv?
    Thanks for the help sory for my bad eanglish. I am from greece.
  • andsolo21
    replied
    Can Anyone help I had one of these tvs given to me today thought it was worth a look, ive done the software update, tv was switching on and off as all the other seem to do but ive lost my tuner, think its the si2156 and it should be the si2157 also checked the service menu and hddp is disabled, am no good with hex editors etc can someone point me in the right direction, tv is a bush led40127fhdcntd
    thanks
  • Greeiejim
    replied
    I dont know if this issue has been resolved yet, I had exactly the same problem, it turned out to be the firmware was corrupt.
    Done a firmware flash update and resolved the problem right away.
    Regards
    Jim
  • FlailingEngineer
    Help with Bush Tv (Vestel 17mb95m Mainboard)
    by FlailingEngineer
    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
    05-31-2023, 06:52 AM
  • Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
    by Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
    03-15-2024, 09:37 AM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • www
    LG L192WS-BN backlight turns off after 1 second
    by www
    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
    03-24-2024, 05:26 PM
  • Chrissygizmo
    Bush led40127fhdcntd possile firmware issue?
    by Chrissygizmo
    I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
    I will upload photos of the mb ,...
    11-03-2021, 08:28 PM
