Panasonic 50" Plasma white vertical line
  • Gipson
    • Feb 2015
    • 10
    • England
    Hi All!
    new to the forum, hoping to get some advice on an issue with my Plasma screen
    I bought the Tv from an auction yesterday, not really having any idea whether it would work or not.
    Got it home, plugged it in and bonus! It turned straight on with everything working as it should, except for one white/grey vertical line on the top right of the screen, extending about halfway down. It is less than a cm in width, very defined edges and is bright white at the top, shifting to a grey on the way down.
    I have taken a few photos to show the issue, but can't find a great deal on the net to explain the problem. Just wondering if it is a common issue or something that can be fixed at home etc?
    I have taken the back off the TV, and although it is very dusty, after a clean all looks to be in good order and all the ribbons etc are connected and clean as they should be.
    Can anyone shed some light on the issue?
    the model is a TH-50PZ70B
    Many thanks in advance! -Dan
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic 50" Plasma white vertical line
    that looks like a chip on film ribbon failure but to be sure you could take the connector off and reconnect it on that driver to see if its just a bad connection. especially since you said it was dirty inside but if not I would be assuming that it's a panel failure
    • jakirsama
      • Mar 2012
      • 5
      Maybe main board i seen many panasonic plasma has same issue if not it could be panel it self
      • Gipson
        • Feb 2015
        • 10
        • England
        Thanks guys! I removed the buffer board yesterday and had a look at that, couldn't see any visual problems and after cleaning all the ribbon connections and refitting the problem was still there. I have ordered a spare buffer board to check that (it was only £8 so worth a shot). is the main board something I could switch out myself as a next step in troubleshooting if I can find a cheap replacement?
        really hoping this buffer board will fix the issue, seems strange that it is a defined rectangle rather than just a random strip. will find out when the post comes!
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          The PZ70 series use address-chips top and bottom. Looks like your upper address-chip in line with the issue has failed. These address chips are part of the panel, so unfortunately the set is stuffed.
          --It wouldn't be a SC buffer board fault--that would give horizontal lines.
          You may get lucky and find a poor connection to that address-chip, but experience says otherwise.
          --You may find that chip gets hotter than the others rather confirming the issue.
          It Wont be a Main Board fault IMHO....
          TELEFIX
          • Gipson
            • Feb 2015
            • 10
            • England
            Hi Alastair, thanks for the reply!
            so the address chips require the full panel replaced then? bugger! I was under the impression that the horizontal lines would be caused by the side buffer (X axis) boards and vertical lines were produced by those along the top buffer board? because If I unplug the corresponding top ribbon the whole block turns white?
            • Gipson
              • Feb 2015
              • 10
              • England
              Replaced the buffer panel today, made no difference unfortunately!
              Should I take it that the little white line of doom is terminal?
              • newtothis
                • Mar 2013
                • 1556
                • england
                Yes, Generally vertical lines are bad panels and horizontal are buffers
                • tw2005
                  • Oct 2011
                  • 6458
                  from the guide for this series
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    PZ70 series was first gen Full HD set.
                    To get all that extra resolution, the maker split the screen into four quadrants and used address-chips top and bottom reaching exactly halfway down the panel, most earlier and later sets dont use address-chips on both top and bottom as tech has moved on and all the screen can be driven by chips from one edge, while earlier 720p could be done with one set of chips....
                    These first gen Full HD Pan. Plasma sets are probably the most complicated and intricate ever made, but usually pretty reliable, just the odd panel failure and PSU issues....
                    I used to have a 42PZ70B, Excellent set with superb picture, sold it some time ago, working well Only drawback was its Huge power consumption and heat generation--505W!....
                    TELEFIX
                    • Gipson
                      • Feb 2015
                      • 10
                      • England
                      Hi Alastair, interesting to know! I did actually spot a sticker in the back there with 2007 on it and couldn't believe my eyes! it is a really modern, good looking telly for the year.
                      And as you mention (apart from the line) the image is flawless!
                      think I will just have to get used to it then, it isn't too distracting really!
                      • Gipson
                        • Feb 2015
                        • 10
                        • England
                        Just on a side note I don't suppose you have a photo handy of the address chips? might give me an idea of which I have to wiggle to see if there is a loose connection!
                        • bdalkiran
                          55EC930V white vertical line appeared (need help)
                          by bdalkiran
                          Dear All,
                          I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                          Please advice how to proceed and what is the...
                          01-13-2023, 04:16 PM
                        • otaku_nut
                          Vizio E701i-A3 fixed but now has red vertical line
                          by otaku_nut
                          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                          08-19-2025, 06:11 PM
                        • TrueSword88
                          Kogan - KALED65XU9220STB - Blue Vertical Line
                          by TrueSword88
                          Hi all.
                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                          Hoping to fix...
                          05-05-2023, 04:28 PM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • almarhum
                          To fix laptop screen vertical line by working on its EDP cable
                          by almarhum
                          Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                          As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                          05-07-2024, 02:12 PM
