First 4K set on Badcaps...? LG 42UB820V
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Spotted this 4K set on the web going cheap private-sale so bought it,--No known faults, just no longer needed. Made in Sept 2014 and is a current model....
    There's nothing actually formally Wrong with the set, but its infuriating irritating POS active-backlight.
    Up and down it goes ad-nausium. It even switches off the backlight during periods between scenes, giving an unnatural dead effect....
    Ive gone into all the various settings, turned on and turned off all the active contrast, backlight, colour enhancement 'Eco power' (bollox) features, but the damned thing still varies its backlight with picture-content, and switches off between scenes--VERY obvious when there's a Scope film or some other letter-box representation such as adverts on screen.
    Plus--The Black-Level is Horrible!
    Its a Grey-Level, and more importantly, and irritatingly a Varying Grey Level.
    There was a scene in a film where it was night. Person facing away from camera with dark hair, turns his head side on--the whole screen lights up grey!
    If I could get the BL to stay put, I could set the picture up for a (For an LCD POS) reasonable, but when varying--its maddeningly impossible...
    Apart from cracking this 4 month old 4K set open--Any ideas on how to disable backlight variation with picture-content??
    TELEFIX
    • 31296
    Re: First 4K set on Badcaps...? LG 42UB820V
    did you check for a firmware update yet?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Well--seeing it was only made in September--err, no I didnt!
      I cant see that they would have one for such a young model yet, but will check....
      I dont like just 'Updating Firmware' for the sake of it, often doing so can cause troubles where there wasn't any!
      As the issue Isnt a fault--I cant see that LG would have altered anything with the F/W for the BL....
      As an observation--Not that it has That much relevence seeing its nowhere near the same model, The 42LE4500 that I just repaired--by potching the BL Controller board out of circuit has in fact a better black-level than this set, as at least with a fixed backlight, its possible to set it up and retain some kind of decent black-level, and no irritating brightness variations....
      TELEFIX
        Contrast ratio will be even poorer for a 4K LCD set, because the pixels are smaller the leakage area to active pixel ratio is much higher. This also means they need a lot more backlight power (at least 50-100% more) Nothing you can do for improving that. 4K sets are made to shift units on specs but not on picture quality.
        Have you tried some service menu access? Samsung sets had this irritating fault (in fact most of them still do, except their higher end models.) You could turn it off in the service menu with the exception of the screen blanking out during full black scenes. (The solution to that was to turn the SUB BRT in ADC CAL up one notch so the black level rises ever so slightly above nominal, preventing the TV from shutting off the backlight.)
        • alltvrepairs
          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
          by alltvrepairs
          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
          Any one met this problem in the past?...
          10-08-2025, 07:34 AM
        • MrCreosote
          2 Belkin KVM switches have dim VGA output
          by MrCreosote
          When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
          4-port Omniview Pro2 f1dz104t
          8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
          The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
          AD ADAPTER:
          There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
          08-15-2023, 08:26 PM
        • _max_
          Hisense H60N5705 automatically switches off
          by _max_
          Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
          Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
          Power cable and HDMI cable checked.
          No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
          So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
          03-07-2025, 06:14 AM
          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
          FF Series (Very Fast Acting), 0603 Size
          Features
          ● Very fast acting at 200% overload current levels
          ● Low DCR
          ● High inrush current withstanding capability
          ● Fiberglass enforced epoxy fuse body
          ● Copper termination with nickel and tin plating
          ● Halogen free, RoHS compliance and lead-free
          Applications
          ● Notebook computers and tablets
          ● Digital cameras
          ● Memory cards
          ● Toys
          ● Bluetooth earphones
          ● Portable electronic devices​...
          10-07-2024, 05:50 AM
        • Txus3232
          INSPIRON 5570 bios maddeningly slow
          by Txus3232
          hi guys, i have dell inspiron 5570 with a maddeningly slow bios.
          specs are: service tag 6MSTDP2 CAL50/DAL10 LA-F115P REV: 1.0(A00) CORE I5 with radeon graphics
          When I turn on the computer it takes approximately 5 to 10 minutes to boot Windows, sometimes up to 15 minutes.
          That slowness is visible even within the bios menu. It seems as if the clock frequency has been reduced drastically
          I already tried some dumps that are in this magnificent forum, I also followed the tutorial by mr SMDFlea​ to make a bios with clean ME region
          But, the result is the same
          I...
          04-26-2024, 03:20 PM
