Sanyo DP46849 No backlight
  • KevinCro
    • May 2014
    • 104
    Hello All. I am troubleshooting a DP46849 that has sound and picture but no backlight. I am reading 1.96 volts dc at BL_ON when the tv is turned on. I also noticed that the led on the front only lights when the power is turned on. I expected their to be a red led when the power is off. Any ideas?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4974
    • New Zealand
    Re: Sanyo DP46849 No backlight
    I think that voltage for a BL_ON signal is borderline too low. What if you try pulling BL_ON high with a resistor?
    Try disconnecting the BL_ON line to the mainboard, then pulling it high (to 5V rail) with a 500 Ohms or so resistor. Connect the resistor after the TV has powered up.
    Do the backlights come on then?
    -David VanHorn
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
