LG 42LD490 intermittently stuck in standby
  • somebodyyouknow
    • Jan 2015
    The tv when first turned on from cold e.g. overnight will not turn on. The red standby light begins pulsing and a high pitch whine is heard. It seems to originate from the main board. The back light remains off.
    If the tv is left trying to boot like this then turned off and on again it will turn on fully functional. If it is turned off after this and turned on again it may or may not boot up.
    The power board has been replaced in the hope it was the capacitors but it did not fix or change the problem.
    The firmware has been updated to the most recent via USB.
    I cannot find a replacement main board anywhere.
    Does anyone have any further trouble shooting pointers?
    Thank you for your time.
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: LG 42LD490 intermittently stuck in standby
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    although i ended up stripping my 42LD490 due to the mainboard being very rare to source one
    have u tried heating up the mainboard with a hair dryer ?
    • lepak06
      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
      by lepak06
      Hello
      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
      01-12-2023, 01:43 AM
    • toty79
      Hisense LTDN50K220WSEU stuck in standby
      by toty79
      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
      As per Hisense tv title LTDN50K220WSEU stuck in standby
      PSU rsag.820.5687 HLL 4855WF
      Main rsag 7.820.5842
      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
      05-01-2022, 04:39 PM
    • lego1234567
      LG 32LB1R - stuck in standby mode
      by lego1234567
      Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
      What could be the problem ? Thanks...
      01-21-2024, 03:39 AM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
    • Rusenga
      Samsung UA39EH5003R Stuck on standby
      by Rusenga
      Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
      Connector CNM803:
      TV ON
      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
      TV OFF
      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
      09-18-2021, 11:51 AM
