Sharp LC-47SB57UT
  • acuser
    • Nov 2012
    • 18
    • usa
    Sharp LC-47SB57UT
    Hi
    Ive had this tv for several years. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until about two weeks ago, sometimes I couldnt get channel 5, now I cant receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5 so I thiink the antenna and cable is ok. Do you think this would be the tuner board or possibly something else? Any ideas where I should start?
    Thanks for any help
    ps If I understood what I read correctly channel 13 in OKC is also vhf and I am able to receive it fine.
  • acuser
    • Nov 2012
    • 18
    • usa
    Re: Sharp LC-47SB57UT
    Resolved.....was a bad cable connection after all
    • eccerr0r
      old X58 triple channel board... memtest86 memory speed?
      by eccerr0r
      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
      06-28-2025, 09:06 AM
    • spleenharvester
      Reverse engineering of 18650 4-channel tester
      by spleenharvester
      Hi friends
      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
      05-04-2025, 02:43 AM
    • mikey5791
      Help on car amplifier only one channel works
      by mikey5791
      Hi all forum members,
      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
      08-06-2025, 10:36 PM
    • jm1234
      Reolink RLC-410-5MP - buck convertor
      by jm1234
      it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
      Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
      07-14-2025, 04:30 AM
    • dicky96
      American Audio VLP1500 Distorting on one channel
      by dicky96
      Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
      Protection and Clip LED are off
      There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
      I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
      The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
      07-13-2022, 05:25 AM
