Vizio M261VP - Doesn't Turn on - Power Indicator Flashes - No Code
  • Nerfinator
    • Feb 2015
    • 56
    I have a Vizio M261VP that when plugged in does not turn on, the white power indicator blinks a bright white and then a dim white, repeatedly while plugged in, there does not seem to be any pattern or time difference between blinks.
    The TV uses an external power supply which checks out at 19v. Links below go to images of the led control board and mainboard. I don't see any blown caps but I may have missed something.
    https://onedrive.live.com/embed?cid=...DUA73_qCwqVrTk
  • Nerfinator
    • Feb 2015
    • 56
    Re: Vizio M261VP - Doesn't Turn on - Power Indicator Flashes - No Code
    Anyone?
    • nomoresonys
      • 12276
      • U.S.
      read the stickies at top of list, try to post some good clear pics. of all the boards and one of the whole back, as to see how they are all connected.
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • odie34
        Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
        by odie34
        I am a hobbyist (not a professional) so please be gentle...
        I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
        I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
        02-18-2024, 09:11 AM
