2 Long 5 Short Flashes on Sharp 60" LC60LE64OU
  • Nerfinator
    • Feb 2015
    • 56
    First and foremost, thank you all for sharing your knowledge. I can't tell you how much so many of us "noobs" appreciate it.
    I have a 60" Sharp, model #LC60LE64OU, that came into my shop. When you press the power button the Sharp logo flashes 2 long and 5 short, nothing appears on the display. On tear down one of the flex cables from the backlight to (what I think is) the T-Con board is burned (see photo). I've procured replacement ribbons but I see no burned components on the board, neither side. All the capacitors look good too, so I'm down to board swapping and was wondering which of the three I should start with? Or are there components I should test instead and if so on which board?
    Thank you in advance, your knowledge is greatly appreciated!
    Re: 2 Long 5 Short Flashes on Sharp 60" LC60LE64OU
    A burnt ribbon like that screams of a bad LCD panel which would not be repairable. Has the TV had water damage? Probably something on the panel is shorted - Sharp panels aren't particularly known for sudden panel death but water will kill any of these modern super thin LED-LCD TVs...
    • Nerfinator
      • Feb 2015
      • 56
      Ok, so just for kicks (and because I have 4 extra ribbons), I installed a new ribbon and turned it on, still get the 2 long and 5 short, but the new ribbon doesn't burn. Still a dead panel or could it be something else?
        Perhaps the fuse has blown on the T-con, or if the LCD has failed dead short completely it's tripping a power supply protection.
        • Nerfinator
          • Feb 2015
          • 56
          I'm not seeing any traditional fuses on the T-con, unless you mean SM capacitors, but I'm not seeing any blown ones of those either. I'm pretty new at repairing TVs but no place else in my city does it, so I'm trying to learn as fast as possible.
            Your picture isn't clear enough but I think I can make out a small surface mount one near the power connector on the T-con. Can you upload a bigger picture looking at the T-con from the top down?
            • Nerfinator
              • Feb 2015
              • 56
              Here is the photo you requested.
              I think I know what/where you're talking about. It looks like there may have been a SMC by the number "4" or am I way off? I have no clue what size it would have been though.
              https://fbcdn-sphotos-d-a.akamaihd.n...10398798_o.jpg
                Those two components with a green near FB4801/FB4901 look to be fuses; try checking them for continuity.
                • marcoclo
                  • usa
                  I had the same issue a couple of weeks ago replaced my power supply and the TV came to life
                    @marcoclo, did you have a burnt ribbon cable too?
                    • Nerfinator
                      • Feb 2015
                      • 56
                      @marcoclo - the power supply is a board on the back of the set. Did you replace the board or does your tv have an external power supply?
                      • Nerfinator
                        • Feb 2015
                        • 56
                        I found a site that lists the LED codes for this make & model Sharp TV.
                        http://www.justanswer.com/tv-repair/...ent-blank.html
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5035
                          • New Zealand
                          Something pretty bad must have happened for the cable to burn...
                          -David VanHorn
                          • Nerfinator
                            • Feb 2015
                            • 56
                            Yeah, the connector for the power cable was bent from the power board, I'm betting that someone tripped on it while it was turned on and it caused a surge as one contact was all but removed from the power connector.
                            • SONY_E-WASTER
                              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                              by SONY_E-WASTER
                              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                              does...
                              12-26-2021, 05:46 PM
                            • Superbee_dad
                              Sharp 80” long short flash backlight error - Help
                              by Superbee_dad
                              Hello Sharp TV experts
                              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                              01-24-2025, 11:51 PM
                            • cm0002
                              Sharp LC-55N7000U 1 long 5 short blinking, no display
                              by cm0002
                              I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                              Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                              I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                              06-19-2023, 06:21 PM
                            • Charrlie
                              Sharp Lc-70le734u blinking 2 long 5 short
                              by Charrlie
                              Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                              So I busted into it and have done the following:
                              -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                              07-07-2022, 02:02 PM
                            • FlorianP
                              Sharp Aquos LC-40LE810E - 2 long, 1 short
                              by FlorianP
                              First of all I am not native English speaking, so sorry for potential mistakes or misunderstanding.
                              I have a basic multimeter and a soldering iron. No electronic pieces for replacement for the moment, but I can buy some.
                              I have a Sharp Aquos LC-40LE810E with issue.
                              When I turn on my TV with the remote control, I have 2 long flashing on the boomerang symbol, and no image/no sound.
                              I saw in the service manual that I need to click on « menu » button of the remote control to have more information.
                              --> Error core...
                              09-05-2020, 10:02 AM
