Panasonic Plasma TX-P50XT50B strange horizontal two lines
  • Damtom
    • Dec 2014
    • 57
    Re: Panasonic Plasma TX-P50XT50B strange horizontal two lines
    I took TV back today to its owner and I find that they are using old satellite box which is showing picture in letterbox aspect with two bars on top and bottom of the screen. This explains problem I had. Apparently box was connected since first day.
    Anyway thank you all for help with problem.
    If someone is interested, I have 3 x faulty power suppliers plus A board for this tv and I am willing to send them only for postage fee.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • busted&disgusted
      Panasonic Plasma TC-P50ST30 Horizontal Black Lines
      by busted&disgusted
      I have a 2011 Panasonic Plasma HD 3D Viera model notorious for the SC board failure. As per a Google for the dreaded 14 blink code I discovered from info on this forum about isolating suspect boards by disconnecting the power cables and using an ohmmeter on the power terminals and this led me to the SC board. I had it repaired by a nearby technician who replaced the shorted transistors and before I got the board back I wondered if any of the buffer boards are damaged and a YouTube showed how to test these by using the ohmmeter and removing the copper colored ribbon cables to the display and use...
      10-05-2019, 09:51 AM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • rstrube
      ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
      by rstrube
      Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
      Hi Everyone,
      I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
      11-23-2025, 01:37 PM
